Thread: Clicking Noise
Results 1 to 6 of 6
  1. #1 Clicking Noise
    Kansas
    Alright... going from park to reverse, as soon as the wheel starts to spin I hear a metal clicking sound.. passenger side. If I don't touch the gas, and let the car idle back it normally doesn't do it. Going from reverse to drive, it will do it again when the wheels start going forward. This does with with the wheels straight as well. I replaced the CV shaft due to it being shot about 8 months ago... might be that. Any ideas? The sound is like taking a long screwdriver and tapping it on a hard surface (i.e. concrete). It started out faint, now slowly starting to get louder, and tonight I seemed to get some mild/medium shaking on hard acceleration while going down the road. From a stop to 1/2-3/4 throttle it won't shake.
    And go!
    '05 GP Base... no ABS nor TCS or other bells and whistles.
  2. #2 Re: Clicking Noise
    GTP Level Member L36 Killer's Avatar
    Jul 2012
    Harrisburg, Pennsylvania, United States
    Could be something wrapped around the axle. My next thought is a tie rod end or even a wheel bearing. You said you replaced the axle. Did you pack the joints with grease?
    "SHELLY" GRAND PRIX GT 02. SLP HEADERS & EXHAUST, K&N CAI, BMR REAR SUSPENSION AND STRUT BRACES, 180 T-STAT, AGX STRUTS, EIBACH SPRINGS, OVERKILL PCM, YELLA TERRA 1.7 ROCKERS, GT1 CAM, SEXMAN PORTED & POLISHED HEADS, STAGE 2 PORTED TB
  3. #3 Re: Clicking Noise
    Kansas
    Well all within the past ~50k miles it has had all new ball joints, hubs, struts, strut mounts, rear brake calipers, rotors, brake pads, passenger CV shaft, and transmission.
  4. #4 Re: Clicking Noise
    any chance its the dust cover hitting the rotor?
  5. #5 Re: Clicking Noise
    Kansas
    I don't think so, plus it would be doing all the time, would it not?
    I'ts going on a lift sometime this week... thinking either CV shaft, sway bar, or transmission. Not really leaning towards transmission as it sounds like an exterior sound, not an internal.
  6. #6 Re: Clicking Noise
    May 2013
    S.E. Michigan
    I've seen many TSBs on 04+ GPs related to loud clicking / popping noises.
    One suggested added a washer to the steering gear-to-frame mounts.
    Another suggested it can need a replacement of the inner tie rod end boot on one of the two sides.
  1. HELP!! Clicking noise
    By Steven Monteith in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-26-2013, 05:21 PM
  2. Clicking Noise
    By Adidasdude1989 in forum Brakes/Suspension/Chassis
    Last Post: 04-14-2012, 02:18 PM
  3. Clicking noise with key on
    By Summit670 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-09-2012, 01:57 PM
  4. clicking noise
    By haasarmy in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-14-2011, 05:04 PM
  5. clicking noise
    By whitegtp in forum Brakes/Suspension/Chassis
    Last Post: 07-23-2009, 05:11 PM
