Thread: Squeaking coming from front subframe area
Results 1 to 12 of 12
  1. #1 Squeaking coming from front subframe area
    Nov 2012
    Ohio
    02 Grand Prix GT. Started squeaking whenever I go over bumps. My first thought was strut mounts. After some crawling around and having a friend bounce the car up and down, it's coming from somewhere near the subframe towards the front of the car. Suspension is fine. Then I thought it was the subframe bushings, after some internet homework, that wasn't it. What else could be causing this?
  2. #2 Re: Squeaking coming from front subframe area
    Sway links can make that noise.
  3. #3 Re: Squeaking coming from front subframe area
    Nov 2012
    Ohio
    Sway bar links were replaced last year. Sorry for not adding that into my post.
  4. #4 Re: Squeaking coming from front subframe area
    Maybe control arm bushings?
    You could try spraying them with wd40 or something and see if the noise stays or goes away.
  5. #5 Re: Squeaking coming from front subframe area
    Nov 2012
    Ohio
    Will try that tomorrow in the daylight. Fivefingerdeathpunch friggin rocks
  6. #6 Re: Squeaking coming from front subframe area
    Nov 2012
    Ohio
    Welp, took me 5 mins to figure it out. Bought a can of WD-40, sprayed the first thing in sight, lower control arm bushing. All is quiet now! used to be embarrassing and loud. Now the question is to have a shop replace just the bushings(both sides) or buy new front lower control arms with the bushings and ball joints already in? I'll likely go this route since I don't have a press nor have access to one. Rockauto here I come.
  7. #7 Re: Squeaking coming from front subframe area
    buy new lca's, they cost 42 bucks a side, new ball joint and bushings, just swap them out. theres a how to here as well, easy to change really. why pay a shop?
  8. #8 Re: Squeaking coming from front subframe area
    If you are fairly close to me I'd swap your lca's out if you buy them for $40
  9. #9 Re: Squeaking coming from front subframe area
    20 a side, thats a deal. better then a shop would charge, and you'll get to see how its done, maybe help and learn.
  10. #10 Re: Squeaking coming from front subframe area
    Dec 2012
    Hawai'i
    What in your guys opinion is the best lca to go with? Excluding zzp, what would you recommend if price isn't that much of an issue but longevity is key
    2002 Impala- SSC, AGX, 18" charger R/t rims w/8mm spacers, Magnaflow cat, U-bend delete, flowmaster 80 series crossflow, z28 tips, HAI, debadged, 35% tint, smoked headlights, full sound system
  11. #11 Re: Squeaking coming from front subframe area
    moogs are good, but dorman are cheap and do last.
  12. #12 Re: Squeaking coming from front subframe area
    I have had dorman for 2 1/2 years now.
  1. Front end squeaking... Help!
    By apierce1289 in forum Brakes/Suspension/Chassis
    Last Post: 04-05-2013, 06:44 PM
  2. Pontiac G6 front end wobble and squeaking?
    By jwjones in forum General Tech Discussion
    Last Post: 02-15-2012, 07:04 PM
  3. 93 grand prix front subframe bushings
    By Mike Preston in forum Brakes/Suspension/Chassis
    Last Post: 01-28-2012, 02:38 PM
  4. Squeaking sound coming from rear wheel
    By skeelo58 in forum Brakes/Suspension/Chassis
    Last Post: 01-06-2012, 06:20 PM
  5. front end squeaking/metallic noise on drivers side
    By bonerjamz03 in forum Brakes/Suspension/Chassis
    Last Post: 09-28-2009, 07:36 PM
