Thread: Given up on coilovers
Results 1 to 18 of 18
  1. #1 Given up on coilovers
    GT Level Member carcrobatics's Avatar
    Dec 2012
    California
    Instead I'm looking to buy some Intrax springs from TM Engineering. I'm going to pair them up with KYB AGX's and yes I'll be getting pogo washers to top it off.
    The golden question here is, do I need to replace my strut mounts/plates/boots or can I reuse my stock ones? None of them have been replaced before but I've never had problems with them performance wise/noise wise.
    '00 GT - Build Thread: XXX - SOLD
    '93 Miata - Drift Project
  2. #2 Re: Given up on coilovers
    Replace the strut mounts and reuse the boots etc if they're still on good condition.
    04 Comp G.
  3. #3 Re: Given up on coilovers
    Dec 2012
    California
    Thanks for the swift reply Red!
  4. #4 Re: Given up on coilovers
    Kansas
    Just my own personal opinion... I would replace the strut mounts while you are there. Save you the time later when they do go out... not if. As for the strut boots... reuse if good like Red said.
  5. #5 Re: Given up on coilovers
    Dec 2012
    California
    Quote Originally Posted by NegativeOne13 View Post
    Thanks for the input buddy!
  6. #6 Re: Given up on coilovers
    Arizona
    Why are you giving up on them?
  7. #7 Re: Given up on coilovers
    Dec 2012
    California
    Quote Originally Posted by 91parkave View Post
    I don't really feel like shelling out $1,400+ for coils that are made with KYB's. I'm really big on the handling department so I have high standards for coils. I can't run really stiff springs with AGX's because their valving isn't good enough to handle them. If I can't run 8k springs (448 lbs) I won't bother.
    Unlike a lot of the people on here I don't care for ride quality. I'm more interested in going fast around corners than fast in a straight.
  8. #8 Re: Given up on coilovers
    Jan 2012
    Canada
    Quote Originally Posted by carcrobatics View Post
    Im running #400 springs and i have no issues with handling at all, Anymore and it seems overkill for these cars IMO, its a 4 door family car not a racecar, dont expect it to handle like one.
    2001 GTP Special Edition - 3.29's built tranny, Coilovers with agx struts, 04+ seats, 18" Eagle 077's, Ported heads, ported blower, pacesetters, 3.4"
    2004 BMW 325CI with the sport package and the correct amount of pedals.
  9. #9 Re: Given up on coilovers
    Dec 2012
    California
    Quote Originally Posted by killerspeed101 View Post
    Yes yes, 4door/wbody/yadda yadda. How often do you hit the bump stops and what's your pogo situation like?
    Really digging the look of your sedan btw.
  10. #10 Re: Given up on coilovers
    Arizona
    So why don't you go with the koni strut cartridge inserts they are made for lower stiffer and shorter stroke setup requirements. 124 bucks a piece
  11. #11 Re: Given up on coilovers
    ^this
    04 Comp G.
  12. #12 Re: Given up on coilovers
    Arizona
    How to here ClubGP:
    You can order them off tire rack just put in 95 taurus sho under suspension and they will pop up
  13. #13 Re: Given up on coilovers
    You sir are a genius
    04 Comp G.
  14. #14 Re: Given up on coilovers
    Ohio
    Most everyone knew that...
  15. #15 Re: Given up on coilovers
    But I neglected to tell him that
    04 Comp G.
  16. #16 Re: Given up on coilovers
    Dec 2012
    California
  17. #17 Re: Given up on coilovers
    Never Never Land
    So where were you loooking at getting those Intrax sprigns? That link to TM Engineering gives a 404 error.
  18. #18 Re: Given up on coilovers
    Dec 2012
    California
    Quote Originally Posted by 4THGENCAMAROFAN View Post
    Yep. They took it down after I tried to order the springs from them.
  1. coilovers help
    By vlocka in forum Brakes/Suspension/Chassis
    Last Post: 04-24-2013, 10:12 PM
  2. Coilovers
    By betz in forum Brakes/Suspension/Chassis
    Last Post: 05-14-2012, 08:34 AM
  3. coilovers? again?
    By biggt in forum Brakes/Suspension/Chassis
    Last Post: 12-30-2011, 02:04 PM
