Thread: New rear struts? Or tires too wide. Rubbing issues
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21 Re: New rear struts? Or tires too wide. Rubbing issues
    Donating User Odi's Avatar
    Chicago South Suburbs
    offset should be on one of the spokes of the rim on the inside, example: ET36
  2. #22 Re: New rear struts? Or tires too wide. Rubbing issues
    GT Level Member Yarbeau's Avatar
    Jun 2010
    Edmonton
    Quote Originally Posted by barnettimpala View Post
    Are your fenders rolled in the rear? If not, that alone will solve everything
    How exactly do you do this? Tried searching couldn't come up with anything.
    2000 Daytona 500 - Tog Headers with catted Downpipe, EGR Delete, 180* Thermostat, Solid engine mount, Poly tranny mount/Dogbones, K&N CAI with a custom tune.
  3. #23 Re: New rear struts? Or tires too wide. Rubbing issues
    Dec 2012
    Hawai'i
    I took mine to a shop. They put a jig on the hub with an adjustable roller that you slowly tighten as you roll and it rolls the inner lip of the tender in. I think I paid 50 bucks to have mine done
    2002 Impala- SSC, AGX, 18" charger R/t rims w/8mm spacers, Magnaflow cat, U-bend delete, flowmaster 80 series crossflow, z28 tips, HAI, debadged, 35% tint, smoked headlights, full sound system
  4. #24 Re: New rear struts? Or tires too wide. Rubbing issues
    i own one of these tools. it's about $250 to buy one and worth it to some people.
    in reality i think i do a better roll without the roller and just using a hammer. the key to the whole process is keeping the fenders HOT with a heat gun so that you don't chip and crack the paint.
    the fender rolling tool is nice to finish off the fenders so that the roll is nice and even and when you need to pull the fenders.
  5. #25 Re: New rear struts? Or tires too wide. Rubbing issues
    Nov 2011
    NY
  6. #26 Re: New rear struts? Or tires too wide. Rubbing issues
    Apr 2011
    Vassar, Mi
    I just put 255/45 17's on a few weeks ago. Stock struts and springs, rolled rear fenders, no rubbing even with 4 people in the car. My wheels had 235/55's on them when I got them and they rubbed all the time even with the fenders rolled so the height has more to do with it than the width. So basically like everyone else said, roll the fenders....run the meats.
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  7. #27 Re: New rear struts? Or tires too wide. Rubbing issues
    Dec 2012
    Hawai'i
    255/45/17? Those gotta look short
  1. the problem is tires or struts??
    By spider4 in forum General Tech Discussion
    Last Post: 11-19-2011, 02:48 PM
  2. How wide of tires can I run on my 98 GTP?
    By ajc549FF in forum Tires & Wheels
    Last Post: 11-13-2011, 03:30 PM
  3. Wide tires
    By monsterjam5000 in forum Tires & Wheels
    Last Post: 03-28-2010, 02:48 PM
  4. Need new Rear Struts
    By NewImage in forum Brakes/Suspension/Chassis
    Last Post: 05-06-2009, 11:12 AM
  5. WIDE tires and rims
    By scoobyydooooooo in forum Tires & Wheels
    Last Post: 03-26-2008, 01:21 PM
