Thread: Broken sway bar
Results 1 to 20 of 31
  1. #1 Broken sway bar
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    Last week,I had a minor click in my suspension turn into a major clunk. I did some investigating myself but found nothing. Took it to a shop and they found the sway bar was completly broken off on the end where it bolts in. They said they had never seen that happen before. Have any of the experts here had a sway bar break off at the end? I will try and post a pic later today after work.
    03 GT 141,000 miles
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  2. #2 Re: Broken sway bar
    Ohio
    It's a common issue here and there. They usually crack at the end and then break if not addressed early.
  3. #3 Re: Broken sway bar
    Quincy, Mass
    Yup very common, in fact will happen to everyone on these cars at some point. Replace it with the Dorman on, it's solid and better made, and get energy suspension endlinks, the moog endlinks are a soft blue rubber that I found wears out fast.
    I'm surprised the shop said that with how common this issue is on these cars. If your not going to do the work yourself then you might want to find a shop that's a little more experienced with these cars. Or find someone local from the forums to help you learn. Fwiw I've seen people drive 4+ hours just to have bill boost work on there car, he did my first 3 builds and I learned enough from him to do the next 3 on my own.
    No more GP 04 Impala SS Indy:
  4. #4 Re: Broken sway bar
    Sep 2011
    MI
    I see it a LOT at the shop I work at. the "bar" is hollow, they sell solid replacements.
  5. #5 Re: Broken sway bar
    same here, one side was snapped off the bar, bolted to the end link still. and the other side was cracked 1/2 way through.
    got a dorman solid bar, it comes with new end links, and caps and bushing.
    i will say the dorman bushings kinda suck, less then a year old and the large bushing are shot already. you may want to find some polly bushings for the sway bar.
  6. #6 Re: Broken sway bar
    Quincy, Mass
    Ya the energy suspension ones are poly, here's the part numbers
    Endlinks Front: Energy Suspension urethane 9.8122G (G denotes black, R is for red)
    Center bushings: Energy Suspension urethane 9-5167g for the 33mm ones dorman bar is 33mm.
  7. #7 Re: Broken sway bar
    Nov 2011
    NY
    My sway end cracked too, changed it before it completely broke off. Replaced it with the GMPP sway. My SE also broke, son has that car now, replaced the sway with the Dorman. Both have from and rear strut tower braces, replaced control arms, HT trailing arms. Only difference is the from sway. I'd say the Dorman has a tighter feel hands down. The energy suspension poly's all around is the way to go!
  8. #8 Re: Broken sway bar
    Feb 2010
    TN
    happened to me changing it is fairly easy
  9. #9 Re: Broken sway bar
    Nov 2009
    A little late
    I was at a very reptuble GM dealership I get a "very good discount" at. Thanks for the replies. Again, the people here know more than trained GM techs.
  10. #10 Re: Broken sway bar
    Quincy, Mass
    Well they had never seen a wbody sway bar break so I'd question how much more they know than gm techs. Don't let them change it to a new gm one though because in a few years that weld will rust out and break like the rest of them.
  11. #11 Re: Broken sway bar
    hes right^^^^ get a dorman, i got mine local for 120. like i said it come with everything you need.
    if you shop the net you can find them for 70 to 100.
  12. #12 Re: Broken sway bar
    Nov 2009
    A little late
    Attachment 11574
    A pic is worth a thousand words.
  13. #13 Re: Broken sway bar
    GT Level Member 02GPinNY's Avatar
    Aug 2012
    Port Chester, NY
    Quote Originally Posted by Swiggles View Post
    I did 2+ Hours to Bill's place and have never been happier!! Whats up Swiggles?! It's Billy here from the Bronx. Me and Richie had a blast with you guys that day. Tons of laughs and got a bunch of stuff done. I'd drive 4+hours if I had to!
    2002 GT Red, Stock, Work In Progress..........
  14. #14 Re: Broken sway bar
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    I put in the dorman bar with NAPA blue poly link bushings this weekend. Would have preferred a GMPP because it is hollow but the dorman was on Kijiji for 1/4 the price of buying one at NAPA. I can't get over how dumb it is to have a solid torsion bar. Working the 15mm wrench on the center bushings was brutal. By the way, has anybody had the links contacting the axles while cornering hard?
  15. #15 Re: Broken sway bar
    Feb 2010
    TN
    Better yet go to a jy like I did find a impala, monte, or gp police cruiser got a super heavy bar for $8.99
  16. #16 Re: Broken sway bar
    Dec 2010
    Canada
    Quote Originally Posted by Logan541 View Post
    No, I wouldn't remove one in a JY if the car depended on it.
  17. #17 Re: Broken sway bar
    Moog end links and inner bar bushings would be nice.
    Might be easier to find than the energy pieces.
  18. #18 Re: Broken sway bar
    Dec 2010
    Canada
    Yeah, I tried for the moogs but these blue poly NAPA's were available, and are probably made by moog in all likeliness. Yet the NAPA guy was insisting they are better quality than moog parts, lol. Whatever the case...
  19. #19 Re: Broken sway bar
    Quincy, Mass
    Moogs are easy to get but I'm telling you they are a waste of money. The links and bushings that come with the bar last longer, my lasted a few months. You can get the energy ones from summitracing.com and you'll have them within a few days.
  20. #20 Re: Broken sway bar
    Quincy, Mass
    Quote Originally Posted by mechguy View Post
    Why is a solid bar dumb? Don't you want it to be stiff to improve the handling?
  1. How to: Replace your broken ol' sway bar or just upgrade it (97-03)
    By Jakescoots in forum How To Write-Ups/Tech Tips
    Last Post: 11-05-2012, 08:35 PM
  2. Old Thread
    By SpeedGrid in forum General Tech Discussion
    Last Post: 09-03-2012, 09:23 PM
  3. ABS problem and a broken sway bar... Oh what a fun day
    By ronmexico in forum General Tech Discussion
    Last Post: 04-15-2012, 11:25 PM
  4. Sway bar broken
    By skibender in forum General Tech Discussion
    Last Post: 01-20-2011, 07:23 PM
  5. How safe is it to drive with broken sway bar
    By blitz217 in forum Brakes/Suspension/Chassis
    Last Post: 12-09-2008, 01:28 PM
