Thread: squeeking when turning?
Results 1 to 5 of 5
  1. #1 squeeking when turning?
    gardner,mass
    So now that the warm weather is coming ive been noticing a squeeling/squeeking type sound from my front right when i turn. Ive recently replaced my bearing cv axle rotors pads. control arms and tie rods look ok. Its like pulsing squeek like a cv axle but ive replaced it twice cus the first one was leaking and it did it with both. Could it be a ball joint, bad rotors, caliper or something. i also noticed my dam brakes squeeking to when i brake. Think i put semi metallic in there so ima replace with ceramics and see if the problem persists.
    and yes i lubed the pads and pins up
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  2. #2 Re: squeeking when turning?
    Maybe the backing/dust plate is touching the rotor.
  3. #3 Re: squeeking when turning?
    gardner,mass
    i thought of this but only when i turn?
    im kind of thinking that since its warmer out my bushings arnt as stiff some are bad
  4. #4 Re: squeeking when turning?
    Ohio
    Could be a balljoint
  5. #5 Re: squeeking when turning?
    gardner,mass
    Quote Originally Posted by MoarkatsINmuhtrailer View Post
    this is what i thinking, ima jack it up an inch off the ground and use a pry bar under the tire and see how it looks
    just really anoying
  1. squeeking noise in front end
    By jbyrne in forum General Grand Prix Discussion
    Last Post: 03-13-2013, 09:28 AM
  2. Car turning off
    By Fatboy in forum General Tech Discussion
    Last Post: 12-05-2012, 04:14 PM
  3. Car not turning over...
    By Bogers04SS in forum General Tech Discussion
    Last Post: 09-05-2011, 11:04 PM
  4. Air bag not turning on
    By izup69 in forum 04+ Specifics
    Last Post: 03-13-2011, 05:56 AM
  5. Turning a 01' SE into a GT
    By Dangerous313KidInAPrix in forum Visual/Body Modifications
    Last Post: 03-03-2009, 09:17 PM
