Thread: rear sway bar bushings
Results 1 to 6 of 6
  1. #1 rear sway bar bushings
    Jan 2013
    Tolono IL
    okay so my rear sway bar bushings are constantly making a squeeking noise and i know it needs to be replaced...but online it said that for my grand prix which is a 2001 GT needs custom made bushings...is that true?
  2. #2 Re: rear sway bar bushings
    antioch ill
    When i bought a new gmpp rear sway it came with bushings. So no its not true
  3. #3 Re: rear sway bar bushings
    Jan 2013
    Tolono IL
    alright..thats what i thought just making sure
  4. #4 Re: rear sway bar bushings
    Mullet Member Wotgtp's Avatar
    Connecticut
    Nope, you can just waltz into a parts store and get some new ones. OR, you could become a corner carver and get an upgraded gmpp sway bar and get some ES bushings and moog end links.
  5. #5 Re: rear sway bar bushings
    Jan 2013
    Tolono IL
    lol i like that idea
  6. #6 Re: rear sway bar bushings
    Nov 2011
    NY
    You can order energy suspension bushings and they are set up with zerk/grease fittings. Only problem is the stock rear sway bar bushing bracket is keyed and not flat. So if you want to use the energy suspension one you will have to drill/tap the steel.
  1. clunking noise. think its the sway bar bushings???
    By Cody Coy Ote Wesley in forum Brakes/Suspension/Chassis
    Last Post: 08-16-2012, 07:39 AM
  2. Poly Sway Bar Bushings
    By 2000SILVERSE3800 in forum Brakes/Suspension/Chassis
    Last Post: 05-01-2011, 04:20 AM
  3. GMPP Sway bar frame bushings???
    By Toasty in forum Brakes/Suspension/Chassis
    Last Post: 09-15-2009, 02:52 PM
  4. P/Ns Sway Bar Bushings for 32mm/22mm Bars
    By TommyGloves in forum Brakes/Suspension/Chassis
    Last Post: 07-14-2009, 05:31 PM
  5. Sway bar bushings
    By TDCRacing in forum Shops and Community Heroes
    Last Post: 09-13-2008, 03:47 PM
