Thread: Brake line leak?
Results 1 to 10 of 10
  1. #1 Brake line leak?
    SE Level Member Mellsthatguy's Avatar
    Dec 2012
    Michigan
    I have a question ! How do i get to the brake line ? I have a leak and need to repair it but need to know where the exact leak is. It seems to be coming from the middle of the rear. What all do i need to remove to access the lines ? Brakes are very spongy
  2. #2 Re: Brake line leak?
    if the leak is in the middle of the car just look under for the wet lines, theres your leak.
    you can cut the rusted line out and use compression fittings and new line, or ( recommended) take the time and buy/rent a flair tool and flair the lines and use line nuts and threaded blocks to join them together.
  3. #3 Re: Brake line leak?
    Dec 2012
    Michigan
    Do i have to remove anything to get TO the brake lines
  4. #4 Re: Brake line leak?
    not really, they run right under the drivers side of the car. may have a clip holding them up here and there.
    jacking up the drivers side and using jack stands is the best way to work under there.
    this is about the middle of the car. see my rust coated lines?
  5. #5 Re: Brake line leak?
    more pics of the lines in this thread, as well as line repair talk. http://www.grandprixforums.net/bad-rust-75107.html
  6. #6 Re: Brake line leak?
    Dec 2012
    Michigan
    But my leak is towards the back of the car by the axle
  7. #7 Re: Brake line leak?
    you just need to look for the wet line, once you find it, have someone pump the brake pedal, you will see exactly where its leaking from then.
  8. #8 Re: Brake line leak?
    Dec 2012
    Michigan
    is the line blocked by anything ? I sorry about all the questions just wanna figure everything out
  9. #9 Re: Brake line leak?
    you can get to all the lines, you just need to find where its leaking from, cut the bad line out and replace it with new line, then bleed the brakes of course.
  10. #10 Re: Brake line leak?
    Dec 2012
    Michigan
    Alright thank you so much
  1. fuel line leak on top of s/c
    By Scottydoggs in forum General Tech Discussion
    Last Post: 01-27-2012, 03:50 PM
  2. RF brake line
    By jpe in forum Brakes/Suspension/Chassis
    Last Post: 01-18-2012, 12:39 AM
  3. Brake line under car
    By donalda in forum Brakes/Suspension/Chassis
    Last Post: 11-01-2011, 12:49 PM
  4. fuel line leak
    By anlo in forum General Tech Discussion
    Last Post: 12-19-2010, 09:39 PM
  5. AC line leak. Here ya go Trannyman!
    By GeddyLee in forum General Tech Discussion
    Last Post: 02-08-2009, 10:58 PM
