Thread: Part numbers
Results 1 to 3 of 3
  1. #1 Part numbers
    Jersey
    Does anyone know the GM and Rockauto part #'s for a 97-03 upper and lower insulators and strut boots front and rear? Im gettting KYB GR2 struts and ssc gen 2 springs.
    16' wrx sti- stock
  2. #2 Re: Part numbers
    St. Louis Mo.
    Front Strut Part Numbers
    22181835 Insulator, FRT SPR LWR (Lower one)
    22181807 Insulator, FRT SPR UPR (Top one)
    From Tire Rack....
    KYB Stut Boot Cover and built in Stopper
    Price: $15.00 (each)
    Estimated Availability: In Stock
    Manufacturer Part #: SB127
    Rear Strut Part Numbers
    10286793 Insulator, RR SPR LWR (Lower one)
    There is no Top Insulator for the rear strut.
    Rear Strut Boot with built in Stopper
    Price: $14.00 (each)
    Manufacturer Part #: SB105
    I would also suggest getting 2 sets of these.
    Eibach Recommended Align. KitProduct Details The performance characteristics of this product place it in both Performance Street and Autocross/Track categories. Front or Rear Fitment Note: Camber adjustment +/-1.0
    Front or rear fitment.
    Price: $26.00 (pair)
    Manufacturer Part #: 5.81260K
    You will need 2 sets of these. This will help with your alignment once your car is finished. One set for each front and rear strut. These go on in the top bolt hole of the struts that connect to the knuckle.
    I hope that helps.
    James Shafer
    St. Louis MO
  3. #3 Re: Part numbers
    Jersey
    I knew u were the person to ask. Thanx, this helps me alot.
    16' wrx sti- stock
  1. National Auto Glass Specs (NAGS) Part Numbers - Grand Prix [*]
    By Abrasive in forum How To Write-Ups/Tech Tips
    Last Post: 10-16-2011, 11:55 PM
  2. GM Delphi-Packard Connector Part Numbers
    By Toasty in forum General Tech Discussion
    Last Post: 08-18-2009, 07:52 PM
  3. Numbers
    By 04 GTP COMP G in forum Off Topic Discussion
    Last Post: 07-10-2008, 02:59 PM
  4. XP cam boost and vac numbers
    By 1998gpgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-27-2008, 10:54 PM
