Ok getting ready to do f body upgrade in front and powder coat all calipers so I want to switch to D.O.T 4 while I am at it. Not sure if my method is sound but here is what I was thinking
1.)Remove all 4 calipers and while I am working them just let everything drain.
2.)Once everything is empty (Pump pedal if I need too )INCLUDING the master cylinder wipe out the inside of the master get it dry as I can
(I can alreday hear some of you yelling "NO!" but hold on).
3.)Disconnect the lines from the master cylinder shoot compressed air and a cleaner through all lines
4.) Replace the rubber brake lines with stainless,
5.)Connect return and inlet lines on the master cylinder to each other with some type a loop type thing (I will fab something).
6.)Fill the master cylinder with D.O.T. 4 and pump pedal to bleed.
7.)Now reattch all lines and calipers and bleed normally.
Should work no?
