As the title states, I'm getting some sort of rubbing around the outer part of the rotor on the drivers side only when making a tight right hand turn. I thought the pads were wearing unevenly so I took everything apart and the pads were fine, but the rotor had noticeable groves on the outer part of the rotor. I figured while I'm in there I might as well change the brake pads and get the rotors turned. So I did that, reinstalled everything and I'm still having the same problem. Any suggestions would be appreciated. Here is s pic of the rotor. Thanks
