I kinda skimmed through the thread. I saw in one post Dave mentioned subframe bushings. That's prob your problem. I chased a clunk and replaced LCA's with new bushings and ball joints, struts, mounts, sway bar links, and motor/trans mounts...only thing left was subframe bushings but I never got to them.
Yeah it is amazing what a full suspension refresh will do for a car.
So parts are on order, what do you guys prefer Poly motor and trans mounts or solid trans mounts?
I asked Vinnie when I ordered the spacers and he suggested it might be a good time to replace them since ill have access when doing the spacers.
Awesome thread Drunkie, they seem to be a good bunch over there at ClubGP, what I gather from that thread is the subframe bushings as you mentioned early on. Parts on there way, ill update with pics as best as I can as they come in.
First on the list is LCAs, Trailing Arms, and the subframe bushings.
Had my new ZZP cat back welded up last night to replace the band clamps and man I was jealous of that lift at the exhaust shop. I hung out under my car as long as the guy was working on it poking at suspension parts!
I bought bmr trailings arms the other day im pretty sure they are the thickest but be careful with low offset wheels they will rub ive been told
Matt just want your opinion on the trailing arms, what was the reason you settled on BMR over other brands or did it matter to you? I dont think my GXPs have a low enough offset to be an issue?
Trailing arms are far enough in, they won't come close to the wheel.
UMI trailing arms are the next biggest for $145 they are also the cheapest for tubular setup
Update I discovered the Clunk!
I dont know what the part is called but im missing a bracket that secures the rear sway bar to the body of the car let me know if you guys know what part this is. And if this is something I could pick up at a parts store or if I had to order it thanks!
alt view
see yeah...what you should have there is a bracket that holds the sway bar down LOL.
Glad you figured out your clunk.
Get one from a yard.
The dealer will want too much.
Yeah the part from Oreilys was off by a few millimeters and so have to get this resolved tomorrow, its weird though knowing exactly what it is and now visualize it. Learned a lot today for sure just poking around. New suspension should be going in tomorrow!
The underside of your car is very clean BTW.
Thanks drunkie
Ran into an issue today. The bolt that secures the lower end of the trailing arm to the wheel assembly is to wide for ZZPs opening on the bushing. Is it safe to drill out that bushing and use the stock bolt?
You will be fine just don't over do it
BTW grease the bolt with anti sieze or something similar
I ended up using a new bolt from Home Depot 5/8th x 4" fit really well but was threaded all the way will that be an issue? Also does some one have a link for the order of the ZZP front sway bar endlinks?
