My passenger front wheel bearing on my 2000 GP seems to be throwing a code and the bearing was just replaced. The ABS light stays on all the time. I checked out the wiring to that hub and it appears one of the two wires are all corroded inside, I'm assuming the wire is broke where the control arm meets the subframe (common spot for the wire to break from my understanding).
So do I need to buy a new harness or can I simply run new wires of my own? They don't seem to be anything special.
