Thread: The dangers of replacing coil springs
Results 1 to 6 of 6
  1. #1 The dangers of replacing coil springs
    Banned
    Feb 2010
    california
    Ben and Russ show want can go wrong when replacing coil springs on a vehicle.
    GT Level Member Utter99's Avatar
    Warsaw indiana
    That the spring I use in my ball point pen
    MY LUGNUTS REQUIRE MORE TOURQE THAN YOUR HONDA PUTS OUT!!!
  3. #3 Re: The dangers of replacing coil springs
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    its something when those let go
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  4. #4 Re: The dangers of replacing coil springs
    I live here. TLSheff's Avatar
    This is why they recommend spring compressors to get it out and slowly let off tension so it doesn't break stuff and/or kill somebody.
  5. #5 Re: The dangers of replacing coil springs
    Just to clarify, OUR CARS SHOULD NOT EXHIBIT THIS! Unless your perch is rusting through or the top nut is fuxored (and to be quiet honest never seen any case of either of those two happening). We do not have a setup like this, we have a MacPherson style strut. Use spring compressors before removing the top nut on the mount. I just want to make that clear. Of course there is an inherent danger when doing this stuff, there is an inherent danger when you get under the car to change the oil (jack and jack stand can fail, you never know when), just use common sense and you are fine.
  6. #6 Re: The dangers of replacing coil springs
    Yoga city
    yes dave is correct, this shouldnt happen to us unless your 1. stupid, 2. your car needs attention, or 3. the spring compressor has malfunctuioned and you now need to sue.
  1. Anyone know about cutting a coil out of your springs
    By WERNE in forum Brakes/Suspension/Chassis
    Last Post: 03-24-2010, 09:12 PM
