I emailed the seller about the spring rates. I will keep everyone updated.
Do you really want to be that guy who puts these on and finds out the valving is garbage?
You'll probably find your worn out bilsteins ride better/the same.
Ask bio about cheap coilovers.
bet if you buy them, revalve them, and put better springs on them you'd have a better set of coilovers than you would have, for cheaper, than if you'd buy them from araut/HT/held.
and i bet after being revalved you can probably get top of the line valving done and they'd be an awesome set of struts.
typically struts can be valved to handle a range of spring rates (say 6k-10k).
Also, after looking at the thread below this one regarding coilovers, it looks like Drunkie suggests 200-300# springs. So, would new springs on these be necessary since they are 250#?
