Thread: Budget Bags
Results 21 to 40 of 67
  1. #21 Re: Budget Bags
    If you gutted the strut how are you going to stabilize the body to the suspension? It will be just like standing on a ball at all four corners.
  2. #22 Re: Budget Bags
    Minnesota
    Il snap some more pics of the tops and bottoms when I get home from work tonight
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  3. #23 Re: Budget Bags
    Never Never Land
    Quote Originally Posted by sgtsnake View Post
    That's really the only way to do it with these. The coil spring sits on top of the strut. The only way to really bag these is replace the coil spring with an air spring. Even the top dollar kits have the same basic design that Ricky is doing.
    Quote Originally Posted by Ricky21 View Post
    Sounds good.
  4. #24 Re: Budget Bags
    Yes but they still have the shaft to tie it all together. The shaft goes through the center of the airbag. You cant just put a balloon on top of a stick and expect it to only move up and down, see what i'm saying.
  5. #25 Re: Budget Bags
    Arizona
    Now that makes perfect sense... and so the factory strut mount just goes right on top of the assembly like normal then? Probably be a better setup anyway cause the bearing would be on a flat surface instead of a spring
    Jan 2009
    Tallahassee, FL
    I always thought that bag systems still had struts for some reason, now I know. I've been dreaming of bags so this should be informative. Good work so far.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  7. #27 Re: Budget Bags
    most bags are just a bag replacing the spring.
    there are a few that are completely independent and use JUST a bag, but a bag over strut setup has become pretty much the norm.
  8. #28 Re: Budget Bags
    Jan 2009
    Tallahassee, FL
    That's how I thought it worked
    77 Morris Garage B
  9. #29 Re: Budget Bags
    Minnesota
    Yea the nicer setups have the struts that go through them, But I know some have just the bag. Soon after I get it up and working I want to figure out a way to put a stand alone strut/damper in there to help stabalize a bit more and help with bouncing.
    Here are the pics, sorry took a little longer than I thought
  10. #30 Re: Budget Bags
    Jan 2009
    Tallahassee, FL
    Look up the Koni retrofits in stock housings for an idea. Gut a stock strut then just insert another strut pretty much.
    77 Morris Garage B
  11. #31 Re: Budget Bags
    Minnesota
    Yea I was reading up on those. It wont work with the set up im going with now. But I thought that would be a good idea for the bags that go over the struts and/or coilovers for more options on spring rates and different valving and such
  12. #32 Re: Budget Bags
    Jan 2009
    Tallahassee, FL
    That's what I got, getting them rebuilt. Unfortunately they don't sell the strut I've got anymore
    77 Morris Garage B
  13. #33 Re: Budget Bags
    Minnesota
    A very small update for anyone interested.
    I got my 60' DOT approved 1/2" airline in with 4 90* brass compression fittings, along with a 1/2" schrader valve for when I do test fitting.
    Doing a little mock up of how to do the top mounts.
    Going to have to file down some of the very bottom plastic piece to try to get it to sit straight as possible.
  14. #34 Re: Budget Bags
    Jan 2013
    Chicago
    subscribed. air ride soon to come on my daytona i believe...any way to save money would be great!
  15. #35 Re: Budget Bags
    Never Never Land
    Any progress on this?
  16. #36 Re: Budget Bags
    This def has potential to work out better than coilovers. Good Luck Guy!
  17. #37 Re: Budget Bags
    Quote Originally Posted by 98GrandPrixIraqVet View Post
    not this way it doesn't.
    unless you meant just for dropping the car. then it will for sure.
  18. #38 Re: Budget Bags
    I havnt drove a GP with coilovers and havnt drove a GP with bags but Im willing to bet the ride would be better than the coilovers and for ND roads the ability to raise and lower with the flip of a switch would be a huge plus. Granted you could just buy a bag setup but if this works out for less than the cost of coilovers why in the hell not!??????
  19. #39 Re: Budget Bags
    since the bag isnt stabilized by a strut its going to have a lot of flex. it's gonna be great for dropping the car, but it wont take corners nearly as well as a coilover car because of the struts...
  20. #40 Re: Budget Bags
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    Very nice. one recommendation. I would throw some washers on those mount bolts.
    97 Bonneville SE Not so much a 97 anymore
  1. My old ride
    By Wadeb79 in forum Members Rides
    Last Post: 02-03-2012, 08:53 PM
  2. air ride
    By Davisgtp in forum Off Topic Discussion
    Last Post: 06-21-2011, 07:31 PM
  3. New Ride :D
    By KawaFord in forum Off Topic Discussion
    Last Post: 05-02-2010, 11:47 AM
  4. bad ride
    By badbrad in forum General Tech Discussion
    Last Post: 03-06-2009, 11:24 PM
