Thread: Help abs problems!!
Results 1 to 5 of 5
  1. #1 Help abs problems!!
    Dec 2011
    Muskegon, Michigan, United States
    I have a 2004 GP gt. when i bought the car i knew a wheel bearing was going out. I ended up replacing both fronts with new timkins. Well just recently my car threw an ABS and Trac code. I put my scanner on it and it said it was the left front wheel speed sensor. I replaced the wheel hub again and the light still comes on even after i clear the codes. Im at a loss for what i should do next. Any help??
  2. #2 Re: Help abs problems!!
    check the wires real good from the plug at the hub to the main harness, they are clipped on the lca's and can get damaged, look for cracks in the insulation, or a a clean break even.
    and clean the plug socket, then dab some di-electrical grease on it.
  3. #3 Re: Help abs problems!!
    Dec 2011
    Alright ill try that. I just got the abs code which is: C0035
  4. #4 Re: Help abs problems!!
    bad wires will throw the same code. its free to look at them...
  5. #5 Re: Help abs problems!!
    Oct 2011
    Oak Grove MN
    fishman like scotty said check the wires leading to the plug. I had one go bad on my 07 near the middle of the car. on a separate not what part of muskegon are you from i used to live there and got family there.
  1. Two Problems
    By tommymcd in forum General Tech Discussion
    Last Post: 02-15-2011, 12:39 AM
  2. Pcm problems
    By Mje00GPGt in forum PCM Tuning
    Last Post: 09-27-2010, 07:35 PM
  3. Got some problems with my '04
    By 04gpking85 in forum General Tech Discussion
    Last Post: 05-24-2009, 02:50 PM
  4. Having Problems...
    By GP3800TC in forum Turbo
    Last Post: 05-21-2009, 09:53 AM
  5. HID Problems
    By That Guy in forum Visual/Body Modifications
    Last Post: 05-19-2009, 10:58 PM
