Thread: Suspension Help
Results 1 to 12 of 12
  1. #1 Suspension Help
    Chicago, IL
    I am looking for aftermarket suspension. Anyone have any recommendations of what to get and where to get it?
  2. #2 Re: Suspension Help
    what do you want? to be lower? to be stiffer?
    there are a lot of answers to that question.
  3. #3 Re: Suspension Help
    .......i say go air.
  4. #4 Re: Suspension Help
    Chicago, IL
    I am looking for stiffer and better handling. I don't want to lower it.
  5. #5 Re: Suspension Help
    Ohio
    Give your gp a bottle of viagra. Ha but on a more helpful note most suggest the kyb agx struts as your best bet for stiffer suspension and being that you dont want to lower i would say stick with stock springs and if you have sagging in the rear you can pick up a set of rear heightening springs to fix that.
    00 GTP demodded and forsale
  6. #6 Re: Suspension Help
    Ohio
    Upgraded sway bars some tubular trailing arms and also strut tower braces will also help to stiffen up your suspension and improve handling.
  7. #7 Re: Suspension Help
    Chicago, IL
    Quote Originally Posted by speedemongtp View Post
    Does KYB make shocks for the 04+ GP?
  8. #8 Re: Suspension Help
    Ohio
    Not specifically but i believe i read that with a few changes you can run the ones for 97 to 03 on your car im not sure what you have to change though. Possibly make a post on it or check in the suspension/handeling section i know there are some posts in there about the 04+ that might be helpful to you
  9. #9 Re: Suspension Help
    GTX Level Member Warhellride's Avatar
    Norfolk, VA; originally from NH
    Some people have swapped in either the CompG or GXP suspensions with good results.
    2004 Mercedes-Benz CL55 AMG
    2002 Redfire Metallic Grand Prix GT Coupe (sold after 141,754 miles)
  10. #10 Re: Suspension Help
    St. Louis Mo.
    Quote Originally Posted by 04gpking85 View Post
    On the KYB site they show that at least the 04's are able to use the GR-2s and the AGX's, anything past that, its a crap shoot, but I dont think there was any dramatic changes between the 04's and up. But I would investigate that more and maybe send an email to KYB and ask them directly to see what they tell you.
    I personally am riding my AGX's with SCC Gen II front lowering springs and stock rear springs. It gives a bit more of an agressive look I think
    James Shafer
    St. Louis MO
  11. #11 Re: Suspension Help
    Hoffman/Schaumburg, IL
    The 04+ the sway bar in the front connects to the strut, where in the 97-03 it connected to the Lower Control Arm, so if the strut isn't 04+ specific, you will need the lower control arms from a 97-03 so you can connect the sway bar.....you may need a different sway bar as well
  12. #12 Re: Suspension Help
    Ohio
    There it is i knew there was somethin you had to change just couldn't remeber what. Thanks for clearin that up an verifying exactly what it is 02BlueGT.
  1. Here I go again, suspension upgrade
    By David99GTP in forum Brakes/Suspension/Chassis
    Last Post: 09-25-2008, 02:08 PM
  2. Suspension 04 GTP
    By Keet04GTP in forum Brakes/Suspension/Chassis
    Last Post: 07-29-2008, 11:12 AM
  3. Need some help with my suspension please!!
    By dementeddj in forum Off Topic Discussion
    Last Post: 02-11-2008, 07:12 PM
  4. suspension ??
    By bayareagtp in forum Brakes/Suspension/Chassis
    Last Post: 02-08-2008, 10:55 AM
  5. Suspension Tech
    By GS-SC in forum Forum Bugs/Suggestions
    Last Post: 12-27-2007, 02:35 PM
