Thread: KYB GR2 + Vogtland = ?? Input please
Results 1 to 11 of 11
  1. #1 KYB GR2 + Vogtland = ?? Input please
    It's Slow LS1GTP's Avatar
    Sep 2012
    Clarkston, MI
    I have new KYB GR2 struts and top plates, thinking about getting some vogtland springs as well. Is the car going to ride like crap? I don't mind a firm ride but its a daily driver so I can't feel like I'm being stabbed everytime I hit a pebble in the road. Also, since I don't have experience with them- will I need the anti-pogo washers, and can those be installed after I have the struts in the car or do I have to pull the struts out and disassemble them?
    Couldn't find many pictures, so if you'd like, post up pictures of your car on vogtlands also.
  2. #2 Re: KYB GR2 + Vogtland = ?? Input please
    Ontario
    Look in the Suspension and such area of the site, and you'll find a sticky with all the pictures of every time of lowering spring.
  3. #3 Re: KYB GR2 + Vogtland = ?? Input please
    vogtland springs are the lightest drop you can get in springs. if you can't handle those then you definitely can't handle a properly lowered car.
  4. #4 Re: KYB GR2 + Vogtland = ?? Input please
    Sep 2012
    Clarkston, MI
    Quote Originally Posted by Oxfire View Post
    WE ARE IN THAT SECTION...the sticky has all the pictures, but the picture of the vogtlands won't show up. That's not a major concern anyway, I just thought people could show their cars with the springs if they wanted to.
    OK, thanks? I don't want a massive drop on my daily driver. My summer car is lowered, I know how it goes. All I was asking was if the vogtland springs will work fine with the KYB GR2's, and if I need the anti-pogo washers, or if there's another alternative to that.
    Anyone have some helpful info that they'd like to share?
  5. #5 Re: KYB GR2 + Vogtland = ?? Input please
    they'll be fine. the spring rates on the vogtlands aren't high enough to wear out the GR2s (now excel G struts) that quickly.
    not sure on the pogo washers. i would think not since the springs are still kind of tall, but i could be wrong. they are subframe washers. get a set from the junkyard for dirt cheap as insurance.
  6. #6 Re: KYB GR2 + Vogtland = ?? Input please
    Sep 2012
    Clarkston, MI
    Cool thanks, now I'm thinking maybe I should go with something that'll drop further, SSC or ZZP...
    Where are the subframe washers that I can take off a junkyard car?
  7. #7 Re: KYB GR2 + Vogtland = ?? Input please
    Sep 2012
    Clarkston, MI
    Also is it hard to install the ZZP engine and trans mount spacers?
  8. #8 Re: KYB GR2 + Vogtland = ?? Input please
    According to your thread, they have the highest spring rate.
    what now?
  9. #9 Re: KYB GR2 + Vogtland = ?? Input please
    Dec 2008
    Lawndale, CA
    Quote Originally Posted by LS1GTP View Post
    Just get them.
    This should be a good read.
    http://www.grandprixforums.net/kyb-e...ech-45867.html
  10. #10 Re: KYB GR2 + Vogtland = ?? Input please
    Sep 2012
    Clarkston, MI
    Quote Originally Posted by The Guz View Post
    Just get them.
    Read that whole thread. Thank you for that. I'm thinking now I'll just stick with my stock springs. The car is a daily driver so it'll be seeing a lot of miles, I don't want my shocks to go bad in no time. It's not worth the $200 and stance to me I guess.
  11. #11 Re: KYB GR2 + Vogtland = ?? Input please
    what now?
    they are?
  1. Vogtland Springs?
    By Pure2sin in forum Brakes/Suspension/Chassis
    Last Post: 09-18-2012, 08:25 PM
  2. Those of you with Vogtland springs, where did you get them?
    By Wotgtp in forum Brakes/Suspension/Chassis
    Last Post: 09-28-2011, 01:45 PM
  3. need some input input input.(short circuit)
    By IR II IP IDEATH in forum 5.3L V8 (LS4)
    Last Post: 02-17-2010, 03:23 AM
