Thread: Car pulls to the left
Results 1 to 7 of 7
  1. #1 Car pulls to the left
    Fargo, ND
    Just noticed that my 02 GT has started pulling to the left slightly. It's bad enough to where I have to counter-act the left pull by turning the steering wheel a bit to the right at all times.
    I'm guessing it's a wheel bearing out? Here comes the stupid question: being that it is pulling to the left, does that mean the left wheel bearing is out? Or the right? What is the easiest way to check?
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    Lift the front of the car and try to wiggle each wheel. Play up and down= wheel bearing. Side to side = bearing or steering component.
    Sent from my Droid
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  3. #3 Re: Car pulls to the left
    Well, a car doesnt just pull to the left for no good reason.
    Did you happen to hit anything lately?
    Possibly rotate the tires recently?
    Under-inflated tire or tires?
    Tires in good condition (good tread, normal wear, not seperated) etc etc.
    Possible brake caliper sticking on that one side?
    A wheel bearing isnt going to cause the car to pull one way or another.
    There are so many possibilites to this problem.
    May 2011
    United States
    Wheel bearing can cause the car to pull. I speak from personal experience.
    Sent from my Droid
  5. #5 Re: Car pulls to the left
    Fargo, ND
    Haven't hit anything lately. No long trips lately either. Mostly just short drives to and from work. If I'm going to do any spirited driving, I'm gonna drive the GTO for that
    The tires have about 70% tread left, just changed the brakes this spring, so I don't think that is the issue either. I have to put my winter tires back on soon anyways, so I'll play around with both sides to see what I can find.
  6. #6 Re: Car pulls to the left
    GT Level Member Peacher213's Avatar
    STL Metro Area
    Quote Originally Posted by skeelo58 View Post
    I agree, My jeep started to pull hard..I thought It was a brake hanging up....about 30 seconds later the bearing broke and It really pulled then. Lol
    99 GTP coupe
    Stock, other than open cone filter.
    GTX Level Member crbquist's Avatar
    Massachusetts
    My car did the same a while back, but to the right. It was the passenger aide bearing. I've been threw 4 wheel bearings between both sides since owning the car. Bad luck I guess.
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  1. GTP, Problem?, Only one wheel pulls.
    By RmRacer in forum General Tech Discussion
    Last Post: 05-29-2012, 04:45 PM
  2. Cop Pulls Out Gun On Motorcyclist
    By E IN v Y in forum Off Topic Discussion
    Last Post: 08-19-2011, 04:36 PM
  3. 2nd gear pulls...
    By IR II IP IDEATH in forum Off Topic Discussion
    Last Post: 12-31-2010, 11:01 PM
  4. Truck pulls
    By TheOtherNick in forum Off Topic Discussion
    Last Post: 09-08-2010, 08:02 PM
  5. 00 gt pulls to right with acceleration
    By racerx217 in forum General Tech Discussion
    Last Post: 03-24-2009, 11:34 PM
