Thread: Best suspension mods for my 40th..
Results 1 to 20 of 22
  1. #1 Best suspension mods for my 40th..
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    Hey guys wanted to get opinions on what is the best suspension mods to run on my 40th gp. It will be built, but also a DD. As of now i have just the BMR Strut Towers and poly motor mounts, billet dog bones, billet diagonal braces, solid engine mount and trans mount, and as far as struts go i have that already i mainly want to know on sway bar, Control arms, Trailing Arms, so that i can start getting the parts since also black friday is on its way and to know what to look out for on the sale section.
    Thanks in advance for the help just want to start getting suspension parts already.
  2. #2 Re: Best suspension mods for my 40th..
    Dorman control arms or Moog.
    Dorman front sway bar, its solid. Better than stock bar.
    Dorman trailing arms, solid design, not stamped steel like stockers.
  3. #3 Re: Best suspension mods for my 40th..
    Buena Park Ca
    Really so go all Dorman? I would figure BMR would be up there for there Lateral & Trailing arms look pretty damn good.
  4. #4 Re: Best suspension mods for my 40th..
    Dec 2008
    Lawndale, CA
    My suspension set up on my DD.
    GMPP front and rear sways
    GMPP Trailing arms (discontinued)
    GMPP lowering kit (discontinued)
    Next Level front and reat strut bars
    Moog Control arms
    My brothers 03
    Vogtland Lowering springs
    BMR Trailing arms
    BMR front and rear strut bars
    06+ Monte Carlo SS KYB struts
    Both ride very similar. Just so you know the BMR trailing arms are the largest available trailing arms. They will rub with a high offset wheel. UMI's are a nice trailing arm and are comparable to the GMPP's.
  5. #5 Re: Best suspension mods for my 40th..
    GT Level Member 00GT's Avatar
    Dec 2011
    Michigan
    Quote Originally Posted by The Guz View Post
    Moog Control arms
    My brothers 03
    BMR Trailing arms
    Really? I thought that UMI had the largest trailing arms.
  6. #6 Re: Best suspension mods for my 40th..
    Buena Park Ca
    Moog Control arms
    My brothers 03
    BMR Trailing arms
    Didnt know that I do love how they look and are adjustable though. I'm just a nob when it comes to suspension and just want the car to stay on the road lol
    would going one brand on everything be best?
  7. #7 Re: Best suspension mods for my 40th..
    Dec 2008
    Lawndale, CA
    Quote Originally Posted by 00GT View Post
    UMI's are about the same size as the GMPP one's. On my brothers 03 we had to install wheel spacers because the bonniville GXP wheels have a high offset and we noticed rubbing marks on the trailing arms. They would be fine on wheels with a lower offset wheel.
  8. #8 Re: Best suspension mods for my 40th..
    Dec 2008
    Lawndale, CA
    Quote Originally Posted by GTP89 View Post
    It doesn't really matter. You can mix and match. Price things out to see which is the most affordable way to go. BMR and UMI tend to have black friday sales. They post their discount codes on ls1tech.
  9. #9 Re: Best suspension mods for my 40th..
    Buena Park Ca
    Nice I didn't know that between UMI and BMR and GMPP what would be best for what part of suspension part to go with?
  10. #10 Re: Best suspension mods for my 40th..
    Dec 2008
    Lawndale, CA
    Since you are out here on the west coast and don't have to worry about rust I would go with the following.
    GMPP handling kit
    UMI trailing arms
    Control arms. There are two choices. Dorman or Moog. Moogs have grease fittings for the ball joints. That is the main difference.
    Also are you planning to lower the car?
  11. #11 Re: Best suspension mods for my 40th..
    gmpp sway bars are pretty small.
  12. #12 Re: Best suspension mods for my 40th..
    Dorman/ADDCO solid front bar
    GMPP Rear sway isn't bad...I'd rather say to get a SLP if you can find one...I think they're the largest ones.
    MOOG EL's
    Pol bushings all around
    New LCA's
    New Lower Mounts/Poly Upper bushings for the dog bones
    Trailing Arms helped out quite a bit on my blue car, so do those.
    Front and rear STB's are cheap...do those too.
  13. #13 Re: Best suspension mods for my 40th..
    Even with GMPP rear trailing arms, rear end wiggles about.
    I had everything except lateral arms, ZZP LCA's and coilovers.
    Still sucked. It'll be better, but suck.
    Just a heads up.
  14. #14 Re: Best suspension mods for my 40th..
    Wider tires helped me too.
    I was also lowered.
  15. #15 Re: Best suspension mods for my 40th..
    Buena Park Ca
    GMPP handling kit
    UMI trailing arms
    Yes definitely going to have the car lowered.
    Just mainly want to get whatever best handling kit I can for the car.
    Dont really care on the brand that i go with as long as it does a good job at what it's suppost too.
    I am assuming BMR isn't that great since no one is really on it? Lol
  16. #16 Re: Best suspension mods for my 40th..
    Lowering doesn't improve the handling that much.
    Most of it is the higher spring rate.
    If you want the best, buy the best, and make them better.
    Buy bilsteins, make coilovers out of them.
    Buy SLP sway bars or ADDCO sway bars.
    Buy the HT motorsports/Held/whatever name they changed to now (seems suspicious yet?) or BMR rear end link kit. Also brace the rear subframe. It flex anyways.
    Make an X brace for the rear strut tower.
    Make a three point strut tower bar for the front.
    Buy ZZP LCA's or invest in having your own made up with spherical bushings. Either way it'll be $500+. Don't buy anything but the newest ZZP LCA's, older ones are smaller, and more prone to breakage.
    Buy a Quaife diff or EP.
    Have 1500-2500 set aside for tires and wheels.
    Willing to bet you won't do more than two of those things.
  17. #17 Re: Best suspension mods for my 40th..
    Buena Park Ca
    Coilovers at the moment not interested i have lowering springs already on KYB GR-2 ready to go in.
    Slp if i can find one for a decent price never heard of ADDCO so gonna look into it.
    WHich is the BMR rear end link kit?
    How do i make a X Brace in the rear or the 3 point strut tower bar for the front?
    Are ZZP LCA's really worth the money? i have been thinking of it for a while now just never made the jump.
    Have tires and wheels already.
  18. #18 Re: Best suspension mods for my 40th..
    Dec 2008
    Lawndale, CA
  19. #19 Re: Best suspension mods for my 40th..
    Buena Park Ca
    For the price of the addco and slp wouldnt going slp be best?
  20. #20 Re: Best suspension mods for my 40th..
    You could buy a rear Addco and front dorman for less than SLP.
    Unless you wanted to talk used.
  1. Replies: 1
    Last Post: 05-06-2011, 07:36 AM
  2. Suspension Mods
    By sdavis11b in forum Brakes/Suspension/Chassis
    Last Post: 06-02-2010, 04:41 PM
  3. Suspension Mods!
    By ponycarman in forum Brakes/Suspension/Chassis
    Last Post: 12-05-2009, 05:00 PM
  4. Energy Suspension Suspension Parts
    By GeddyLee in forum Brakes/Suspension/Chassis
    Last Post: 03-09-2009, 10:25 PM
