Thread: intermediate shaft dorman
Results 1 to 8 of 8
  1. #1 intermediate shaft dorman
    Donating Users
    phila pa
    Hi did anybody try the 425-135 dorman shaft. Need won just wanted to see if any good .thanks ron 2001 gtp
  2. #2 Re: intermediate shaft dorman
    i swapped mine with a used one a while back. i can tell you this, its no fun to change.
    once you have it off do not spin the steering wheel round and round, the clock spring will break.
    i also found it easier to drop the sub frame a few inches to get the shaft back on the rack. the inside part of the column is a pain to get back on as well, due to the boot around it, top and bottom side, and getting the shaft back down the tube is no fun either. spreading the ends of the shaft ends helps some.
    dorman usually has good parts, so i would have no problem using it.
  3. #3 Re: intermediate shaft dorman
    Donating Users
    phila pa
    hi installed the dorman shaft what a pain. Know the car is really lose steering .could the rack be bad. or is the dorman shaft no good. old shaft was a little loose but had clunk.new shaft is really loose all over road. Thanks Ron.
  4. #4 425-135 dorman shaft top joint loose
    Donating Users
    phila pa
    hi put in 2001 gtp 425-135 intermediate shaft top joint lose .any body else try a dorman shaft.I thing they are making gm shafts too .old shaft just had clunk.aslo new rack.
  5. #5 Re: 425-135 dorman shaft top joint loose
    I run napa axles. They have a warranty and I've never had an issue with them.
  6. #6 Re: 425-135 dorman shaft top joint loose
    There you go. I merged your threads for you.
  7. #7 Re: 425-135 dorman shaft top joint loose
    Donating Users
    phila pa
    put back in old shaft grease it real well so far works find. had a bad dorman shaft 425-135 was real loose.
  8. #8 Re: 425-135 dorman shaft top joint loose
    Donating Users
    phila pa
    had to get a gm shaft work fine dorman shaft was a pice of junk.had 2 bad dorman shafts.
  1. intermediate steering shaft
    By mstowe in forum Shops and Community Heroes
    Last Post: 10-08-2013, 07:02 PM
  2. Steering Intermediate Shaft
    By stlmo_gtp in forum Brakes/Suspension/Chassis
    Last Post: 07-06-2009, 12:22 AM
  3. Intermediate steering shaft?
    By 04muscle in forum Brakes/Suspension/Chassis
    Last Post: 03-24-2009, 07:30 PM
  4. Intermediate Steering Shaft.
    By bentendo92 in forum General Tech Discussion
    Last Post: 09-18-2008, 07:04 PM
