I am pulling my hair out with ABS/Traction Control lights. Was told about a year ago (due to having the car in for something else) that the front driver ABS sensor wires on the wheel bearing were chaffing because a previous owner didn't put the bracket back on when they replaced the wheel bearing hub so the ABS wire was just dangling. Anyway, I made a temporary fix by using a strategically placed zip tie (not tight) to the tie rod to hold it away from rubbing.
Anyway, the damage was still done, and last night I decided to finally just replace the hub (old and new ones were both Timken) and I picked up a replacement bracket from a forum member here.
So I am excited to finally have this fixed and to stop my car from having the ABS and/or traction control kick in randomly while driving (or stopping) which not only wears on the brakes, but makes for some scary stops.
I pull out of the driveway, and the Traction Control light comes on for 3-5 seconds, and then within about a minute of driving, both the ABS and Traction Control lights came on. UGH! I pulled the car back in and did my best to look at wiring, but didn't see anything obviously wrong. I could spend a ton of time looking into this, but I thought that maybe I would see if there were any code scanners that would read ABS that would be inexpensive? I figured for the cost of a diagnostic at a dealership, maybe I could get something to read the ABS codes (I use the Torque app for regular CEL codes).
I would rather spend a few bucks on a scanner that I can keep, or if I must, take it to a dealership and have the codes read instead of spending endless hours guessing where to focus my efforts.
Any ideas?
