Thread: Question about Changing Brake Line
Results 1 to 4 of 4
  1. #1 Question about Changing Brake Line
    May 2012
    Tracy, California
    My rear right brake line broke on my 1997 Pontiac Grand Prix GTP on the part where it snakes up by the gas tank and i replaced that part by unscrewing it from the rubber tube connecting to the caliper and unscrewing it where it connects to the line that goes up to the master cylinder. Well some sort of vibration from taking out that part of the brake line caused the other part of the brake line to spring a leak. So now I have to replace the whole line that goes up to the master cylinder. Now my two questions are as follows:
    1. What are the arrangements of brake lines on the actual master cylinder? (I know it says on the master cylinder but i just want to confirm them)
    2. Is there a special wrench size to take off the brake lines from the master cylinder? (I tried a 12mm and an 11mm and the 12 was too big and the 11 was too small)
    Thanks for all of your help.
  2. #2 Re: Question about Changing Brake Line
    You need a line wrench for the lines so you don't round them off. When i was doing a brake line on mine a while back I used a 10mm, 12mm, and 13mm i believe.
  3. #3 Re: Question about Changing Brake Line
    GT Level Member Tony Mendez's Avatar
    Aug 2012
    Somerset WI
    This may not apply to your car but I have encountered GM brake lines that were inverted flare on one end and metric bubble flare on the other. Make sure you look at the ends as some parts counter guys may be unaware of this.
  4. #4 Re: Question about Changing Brake Line
    GT Level Member 00GT's Avatar
    Dec 2011
    Michigan
    Also make sure if you use a new fitting on the new line going into the master cylinder that you get the same thread as the old one. On my 97 i used to have i looked at one and thought they were all the same. Ended up stripping out the master cylinder because there are different threads on every other fitting. It wasnt like that on my 2000 i have now, so idk if your car will be like that or not. Just something to watch out for.
  1. RF brake line
    By jpe in forum Brakes/Suspension/Chassis
    Last Post: 01-18-2012, 12:39 AM
  2. How dirty should brake fluid be before changing it?
    By skeelo58 in forum Brakes/Suspension/Chassis
    Last Post: 11-14-2011, 10:10 PM
  3. changing brake lines
    By mdotson29 in forum Brakes/Suspension/Chassis
    Last Post: 06-24-2011, 12:33 PM
  4. Brake line question
    By frankjc in forum Brakes/Suspension/Chassis
    Last Post: 07-26-2010, 07:19 PM
  5. Fbody brake line question
    By minichopper6hp in forum Brakes/Suspension/Chassis
    Last Post: 05-09-2009, 05:00 PM
