Thread: Slight upgrade
Results 1 to 6 of 6
  1. #1 Slight upgrade
    Jersey
    Hello everyone. Ive been thoroughly reading the big bad brake forum and i have a question about the slight upgrade. Will it be ok to just get the 04 gp calipers & rotors for the front of the car and keep the 97 gp calipers & rotors in the back for the moment? Money is tight and im in desperate need of a pad change (had the car for 2 years and never touched them smdh ). Will it make a major effect on how the car stops? I have a 97 gp se btw....i need to get this done. Help is much appreciated....thanks!!
  2. #2 Re: Slight upgrade
    antioch ill
    im pretty sure you would need the brackets for the bigger brakes id imagine dont quote me on that
  3. #3 Re: Slight upgrade
    New rotors and quality pads is all you need to make it stop better and its cheaper than having to buy calipers and brackets aswell.
  4. #4 Re: Slight upgrade
    the easiest/cheapest method is 04 monte carlo brake calipers brackets/rotors/pads (pads are same as yours now) and your stock calipers.
    Won't make much of a difference, pad choice will make a bigger difference.
    Just less likely to cook the rotor.
    But I haven't found many on here cook the rotors, just claim to, but no heat cracking.
  5. #5 Re: Slight upgrade
    Jersey
    Ok i have a few choices to decide. Thanks alot guys!!!!!!!!!!!!!!
  6. #6 Re: Slight upgrade
    i fade my brakes all the time. tiny econobox brakes, yay.
  1. Slight Vibration
    By chevyy1212 in forum Brakes/Suspension/Chassis
    Last Post: 06-25-2012, 10:05 AM
  2. Headlight and FogLight Upgrade (to upgrade to HID or not?) Please Help???
    By Michigan04GrandPrix in forum Visual/Body Modifications
    Last Post: 04-20-2012, 12:53 PM
  3. Slight hesitation while revving
    By dsmuts in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-17-2012, 01:48 PM
  4. Shaking during slight acceleration
    By zeppelin913 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-20-2011, 11:55 AM
  5. Slight vibration.........
    By Texas Bullet in forum General Tech Discussion
    Last Post: 12-31-2010, 04:54 PM
