Thread: W Body mount on an H Body
Results 1 to 4 of 4
  1. #1 W Body mount on an H Body
    GTP Level Member
    Pittsburgh
    This is a mod that I have been Planning for years.
    The Stock Bonneville mount setup consists of 2 mounts on each side of the car and one lower front trans mount and a rear trans mount. There is only one mount that is a vertical support that physically attaches to the engine. The Trans case takes all of the restraint and all of the pressure.
    The stock lower front trans mount is Jell-o and really lets the motor move around. All Bonneville, Lesaber, Aurora, Deville and Seville use this location for the front lower mount.
    The Front mount is really terrible and tends to rip apart. I got mine changed before any thing bad happened to it.
    The upgrade is the hockey puck mod
    the Trans mount also needed attention also. When I installed the built trans I got a new mount and used Poly to fill it, and that also greatly improved the feel
    The stock mount would totally compress the open areas. I could watch the compression when any power was applied.
    New Poly Fill on the left stock on the right
    The Combo made the car more drivable, and not as soft feeling.
    Onto this mod. I had a few students that needed some live hours and said they would be up for this project....so it began.
    Stock Parts
    Planning the new stuff
    Disassembly
    Had to remove some metal from the car
    This is what was cut out
    And it belongs here
    2003 SSEi,
  2. #2 Re: W Body mount on an H Body
    GTP Level Member
    Pittsburgh
    And it belongs here
    Ok so on to the design phase
    We decided to use 1 and1/2 inch round stock for this support bar for the mount
    Let the welding begin.
    Everything is measured, squared up and welded
    and now to test on the car
    Now fitted, time to sleeve the bolt holes
    Final Size of the Sleeves
    Sleeves being milled out
    Installed
    To Retain the factory appearance the Stock support is retained
    Scribe line to cut the bottom out of the support
    and totally cut
    Now for the Mount
    Took a stock W body mount and had to....modify it.
    Cut in half
    Took 2 Dog bones and fabbed up one.
    First we Mig'd the Mount together with Tacks and then it was fully Tig'ed
    2003 SSEi,
  3. #3 Re: W Body mount on an H Body
    GTP Level Member
    Pittsburgh
    Tig work
    Once we mades flanges one more cut to the factory support
    and the Final Result... (its not painted in the pics this was still in the shop. I metal finished the welds on the and painted the mount)
    With the extra support upfront, the car is 'tied" together more, it does seem to handle better in the corners, and there is still a little Engine movement. Its impossible and not feasable to remove ALL movement. This extra mount adds enough bracing with out any real damaging effects. I have been driving on this setup for 2-3 months now and its like a different car (getting power to the ground) than it was with the stock mounts.
    Best thing is that it looks totally stock and factory.....I even had people ask when the Bonneville started to use the dog bones :Thumbs
    2003 SSEi,
  4. #4 Re: W Body mount on an H Body
    Where's the final product picture? CF looks good on it.
  1. Body kit help! 96 Grand prix SE 4 door, to possible GTP body kit?
    By afeenaughty in forum General Grand Prix Discussion
    Last Post: 06-29-2012, 08:46 PM
  2. H-Body Bonneville Seats into an H-Body Oldsmobile
    By acidcrashdburnd in forum Other Vehicles
    Last Post: 06-20-2012, 06:27 AM
  3. new body wrx
    By 99prixgt in forum Track Sessions and Kills
    Last Post: 11-21-2009, 09:54 AM
  4. Major loss to the G-body/W-body community
    By Sabrewings in forum Off Topic Discussion
    Last Post: 05-21-2008, 03:47 PM
