Thread: Jacking points
Results 1 to 15 of 15
  1. #1 Jacking points
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    Where is everyone's favorite spot to put a floor jack when raising the front end for repair? Does anyone think it is critical to use the spot behind the front wheels the manual suggests? I am tight on room in the garage.
    Thanks
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  2. #2 Re: Jacking points
    GT Level Member 00GT's Avatar
    Dec 2011
    Michigan
    Those are the only points I use. I think there might be another spot in the front to jack it up though.
  3. #3 Re: Jacking points
    Resident ZZP Leg Humper BoostenGTP's Avatar
    Grand Rapids, MI
    I would ONLY use the frame itself, a lot of people use the pinchweld but IMO that's retarded.
    2014 Mustang GT Sterling Grey 5.0 Track Package NEW 2000 Grand Prix GTP Red SOLD
    2000 Mustang GT LTR SOLD 2000 Grand Prix GTP Silvermist SOLD
  4. #4 Re: Jacking points
    Nov 2009
    A little late
    The pinchwelds at the sides of the frame rails outside the motor is where I was thinking about, but the metal looks awful thin. If I pull the handle off of the floor jack and use something in its place I might have room. Thanks.
  5. #5 Re: Jacking points
    Grand Rapids, MI
    The Pinchwelds on these cars are not strong enough anymore, from the factory they were, but unless you have a car that has never seen an ounce of road salt, you'll probably just crush them trying to jack the car up, and then you have big problems.
  6. #6 Re: Jacking points
    Nov 2009
    A little late
    How about jacking just behind the radiator under the crossmember? To me, it does not look very strong.
  7. #7 Re: Jacking points
    Grand Rapids, MI
    My car was too low to get a jack under that part, but thats the cradle. It should be alright.
  8. #8 Re: Jacking points
    GT Level Member Beelzeboul's Avatar
    Racine
    yeah thats what I normally go with I used the suggested spot for my jackstands and afterwards it warped disintegrated anything within an inch of where they stood didnt make me feel to comfy. I will normally use the frame behind the radiator to jack and than the corners for my jackstand and I feel safe...I still put jackstands at the drip edges for back up when I really need to get it up and use a 4x4 as spacer between the jack and frame but I find either way using the wood helps keep it lvl on the way up and gives ya an extra cpl inches of lift
    I'm sorry officer I didnt know I couldn't do that
  9. #9 Re: Jacking points
    Feb 2010
    TN
    I agree but while we are at it does anyone know a good point to jack up the back end and get both wheels off the ground at once
  10. #10 Re: Jacking points
    The centre of the rear "subframe" has a nice point to get to.
    It might be difficult or impossible with a large floor jack and/or aftermarket exhaust though.
  11. #11 Re: Jacking points
    Dec 2011
    Michigan
    I've used the center of the rear subframe before with a large jack. Had to be very careful lowering it down. Jack was touching the exhaust pipe. If you use this point I would recommend using a small jack.
  12. #12 Re: Jacking points
    Front: Subframe
    Rear: Subframe with block of wood to clear exhaust better.
  13. #13 Re: Jacking points
    pinch weld to get the car off the ground enough to put a real jack under the front of the car.
  14. #14 Re: Jacking points
    Nov 2009
    A little late
    I finally got around to changing my oil. I jacked under the pinch points high enough to put a 6x6 under the front tires. I was surprised to see the back end start to come off the ground a bit. If I keep doing this, will it compromise the alignment or suspension? Worked real good though, had another extra board next to the 6x6 and just backed the car off the boards.
  15. #15 Re: Jacking points
    Aug 2012
    florida
    car ramps
  1. lift points
    By gtp99 in forum General Tech Discussion
    Last Post: 08-14-2012, 11:15 AM
  2. Shift Points
    By torq455 in forum General Tech Discussion
    Last Post: 10-29-2010, 06:53 PM
  3. Shift Points
    By RicerKiller in forum PCM Tuning
    Last Post: 03-24-2009, 01:19 AM
  4. Rep points vanished ???
    Last Post: 11-03-2008, 05:43 PM
  5. Jacking points during trans install?
    By nlinesk8s in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-26-2008, 07:33 AM
