nik12937
On my 05 GP GT, there are several noises definitely related to the suspension or technically powertrain if it involves the CV axles. I want to try to pin down what all of the noises are because I'm planning on ordering parts this Friday to get my suspension back up to par, and a little some.
First off there's an off clunk when my car rocks left to right at slower speeds, anything above 5 mph and it would be dangerous/reckless to try to recreate the sound, but I'm thinking it's the sway bar end link. The driver's side one has a bit of play, or at least it did several weeks ago, I bet it's horrible by now D: I plan on upgrading to a GMPP rear and Dorman front with endlinks.
Secondly there's a rattle coming from what I believe is the front right wheel. As soon as I start traveling over about 45-50 mph it begins and gets louder as I increase my speed (it used to start at 60-65 mph). I'm already purchasing new lower control arms in order to run the bigger front sway bar, and I'm thinking that possibly the bearing is going out on that wheel? If So I plan to buy a replacement.
On top of that, just recently I've noticed this horrid, terrifying sound only while under heavy acceleration, at lower speeds where the torque is really putting stress on the wheels. It sounds like grinding/scratching, and I can only hear it with the windows closed and music off, but I feel like I should fix that now before it gets bad. I was thinking possibly a bad CV joint, and I'll check under the car early tomorrow for damage to any of the boots. I'm hoping it's the passenger side, as that could explain the wheel bearing, and if so I'll just purchase a whole new CV axle for peace of mind.
Finally, and this one I have no idea what it could be, the back end squeaks when going over bumps, slow or fast, and kind of screeches almost (it's an odd sound) when the rear end hits a bump at higher speeds.
I apologize for the long post, I tried my best to make it clear and searched at least twenty-some times, so I think I may know what most of the noises are coming from, but I'd like to make sure before I go and order all of these parts.
