Thread: f body brake upgrade fail......defeated and need help
Results 21 to 40 of 44
  1. #21 Re: f body brake upgrade fail......defeated and need help
    GT Level Member Vegas~Blown's Avatar
    Aug 2008
    vegas
    Quote Originally Posted by asite57 View Post
    all data says this is the order for my 99 grand prix
    this is the correct order.
  2. #22 Re: f body brake upgrade fail......defeated and need help
    Texas
    You aren't the first and won't be the last.
    85 Corvette
    01 TA
    03 Z06
  3. #23 Re: f body brake upgrade fail......defeated and need help
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    well it worked the brakes could stop the car....but the passengers side is dragging and the pedal is super super spongy
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
    Buffalo
    I just did this last week. The spongy feeling could just be from the stock rubber line might be aging or the pads need settling in. One mine had some hard stops , they are very grabby now
    Bleeding can be key to avoid a spongy pedal. Best is using 2 people. One to press pedal down until its firm then hold it there while you open bleeder. Push the pedal to the floor until fluid stops coming out with air. Close bleeder and pump up the pedal again. eventually just fluid will come out and no air.
    Also remember to bend out your brake line bracket where it attaches to the frame of the car. That will give you more reach with stock lines
  5. #25 Re: f body brake upgrade fail......defeated and need help
    Bleed them again.
  6. #26 Re: f body brake upgrade fail......defeated and need help
    Oct 2011
    Michigan
    thank you crazyguy03 i think everything we went over sums up the problems and yes they will get bled again and probably again
  7. #27 Re: f body brake upgrade fail......defeated and need help
    are you doing the 2 person bleeding procedure?
  8. #28 Re: f body brake upgrade fail......defeated and need help
    bleed the abs pump too. when the brake pad burn in, they will feel tighter and tighter, and work better, just ride them nice for a few days, no hard stops over and over. nice and easy for a few days.
  9. #29 Re: f body brake upgrade fail......defeated and need help
    You could save face if you say they are the F body calipers. Because to fit our application we put them on the opposite sides from their markings. Meaning the L caliper goes on the R of our cars because of where they are located on the F body knuckle vs ours.
  10. #30 Re: f body brake upgrade fail......defeated and need help
    Oct 2011
    Michigan
    O.M.G.
  11. #31 Re: f body brake upgrade fail......defeated and need help
    ask Swiggles... we went through 3 of the large bottles during bleeding his car. I never touched the bleeders...and didn't see them pointing to the ground. learned something that day.
  12. #32 Re: f body brake upgrade fail......defeated and need help
    Oct 2011
    Michigan
    as have i bill as have i
  13. #33 Re: f body brake upgrade fail......defeated and need help
    That's the first clue right there...how can you bleed it and use so much fluid..
  14. #34 Re: f body brake upgrade fail......defeated and need help
    Oct 2011
    Michigan
    we were at a loss by that point it was late everyone went home i posted here and my problem was solved
  15. #35 Re: f body brake upgrade fail......defeated and need help
    Next time...get the write up and when things don't seem right... post.
  16. #36 Re: f body brake upgrade fail......defeated and need help
    Oct 2011
    Michigan
    yeah i learned my lesson
  17. #37 Re: f body brake upgrade fail......defeated and need help
    Oct 2011
    Michigan
    UPDATE!! alright so i got the system completely bled and bent the metal clip ive been taking it easy and havent brought it down harder then 50-0 yet just driving around town lite braking and the brakes feel the same no monumental difference idk if i just expected more or what lol i did have to slam on the brakes at like 25mph because some lady stoped short in a neighborhood and it stopped on a freakin dime, is that where these really shine over stock the hard stops?
  18. #38 Re: f body brake upgrade fail......defeated and need help
    i'd say the top 1/3 of the pedal feels very much like stock. but when you nail them, you have BRAKES!
  19. #39 Re: f body brake upgrade fail......defeated and need help
    Oct 2011
    Michigan
    yeah alright thats how they feel and i was just wondering if it was right the only other GP ive ever drivin was the 07 GT we had
  20. #40 Re: f body brake upgrade fail......defeated and need help
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    Get the ss lines it helps with a firmer pedal feal when I did my setup on my 40th I felt a huge difference especially at high speed they just bite down so much better over stock. And plan on doing this to all my gp. Don't plan on settling with stock after experiencing the difference.
  1. F-body brake upgrade
    By wpbboy81 in forum Brakes/Suspension/Chassis
    Last Post: 11-04-2011, 12:52 PM
  2. body kit+altezza tails+spray paint job=rice fail
    By jakewet28 in forum Off Topic Discussion
    Last Post: 02-18-2011, 04:26 PM
  3. brake parts to get for brake upgrade??
    By colindunn in forum Brakes/Suspension/Chassis
    Last Post: 01-03-2011, 08:59 PM
  4. F-Body Brake Upgrade
    By Phyrstorm in forum Brakes/Suspension/Chassis
    Last Post: 07-19-2010, 05:53 AM
