Thread: rear brake lines
Results 1 to 16 of 16
  1. #1 rear brake lines
    Jun 2012
    worcester
    im replacing the rear brake lines in my 99 grand prix. i have rotors in the back and abs. i ran into a problem and im wondering can anyone tell me if i can eliminate the reducer cylinder that is on the rear brake lines on both sides or will that cause the tires to lock up?
  2. #2 Re: rear brake lines
    post a pic of what your talking about, theres nothing between the the cars frame and the caliper, along the brake lines.
    never heard of a reducer cylinder.
  3. #3 Re: rear brake lines
    Jun 2012
    worcester
    im uploading a picture now. not really sure of what it is it seems to me that it is there to allow a certain amount of fluid through and not let it back out
  4. #4 Re: rear brake lines
    No you need that.
    They are the proportioning valves.
    With them the rears will lockup well before the front.
  5. #5 Re: rear brake lines
    Jun 2012
    worcester
    heres the "cylinder"
    rear brake lines Attached Images
  6. #6 Re: rear brake lines
    I'd leave that alone, it also looks like you have had a brake line repair done already, looks like a compression fitting under the part in question.
  7. #7 Re: rear brake lines
    Jun 2012
    worcester
    so where can i get the fitting that goes into that because i wrecked the fitting and could not find it at the parts store that i went to, its a 3/16 line that goes into a larger fitting
  8. #8 Re: rear brake lines
    sorry im not following you, witch fitting is messed up? is it just stripped, like a rounded flare nut?
  9. #9 Re: rear brake lines
    Jun 2012
    worcester
    its on the other side. the side that i sent you was fine. its the other side that i stripped out the fitting. its the fitting that goes into the "proportioner valve" which is bigger than the fitting that comes out of the valve
  10. #10 Re: rear brake lines
    do you have a leaky line? why are you after this part?
  11. #11 Re: rear brake lines
    Jun 2012
    worcester
    because i had to replace the line and when i took the fitting out to get the line out of the fitting i crushed it in the vice
  12. #12 Re: rear brake lines
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Someone please double-check me, but I believe the part he needs is DORMAN Part #905952. I don't have the proper GM part number, but this should be a good equivalent. $15 for one on RockAuto.com, maybe other online stores as well. Also, if that is a compression fitting holding two brake lines together in that picture, REPLACE THE LINE. Compression fittings aren't made to handle that amount of pressure...that moment you slam on the brakes because you REALLY need them, the fitting will burst. If you don't want to replace the whole line, at least bubble flare both ends of the line and use proper fittings and a union there.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  13. #13 Re: rear brake lines
    Jun 2012
    worcester
    that is the valve but im not looking for that i am looking for the larger fitting that goes into that valve
  14. #14 Re: rear brake lines
    Quote Originally Posted by cboulette View Post
    oh boy you really did it good this time. check out the other guys post for that part, see if it matches up.
    if you go to a parts store or dare i say the dealer, they have diagrams you can look at to make sure your getting the right part. right on their pc screen for you.
  15. #15 Re: rear brake lines
    Jun 2012
    worcester
    ok thanks for the help
  16. #16 Re: rear brake lines
    Compression fittings FTW!! I've been running compression fittings on the rear brakes of my car for over a year now with no problems. Quite a few emergency stops too. If the rest of my car wasn't so rusty I might replace the lines but I figure it's only a matter of time until my car falls in half.
  1. changing brake lines
    By mdotson29 in forum Brakes/Suspension/Chassis
    Last Post: 06-24-2011, 12:33 PM
  2. Brake Lines
    By siupilot in forum Brakes/Suspension/Chassis
    Last Post: 08-10-2010, 09:34 PM
  3. Rear Brake Lines on 98
    By johng80 in forum Brakes/Suspension/Chassis
    Last Post: 09-10-2009, 08:56 AM
  4. It's not the P.O.S ss brake lines?
    By 99prixgt in forum Brakes/Suspension/Chassis
    Last Post: 01-20-2009, 09:09 AM
