Thread: are stainless steel break lines worth it?
Results 1 to 10 of 10
  1. #1 are stainless steel break lines worth it?
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    are SS brake lines really worth $115 bucks? im upgrading to a 12" brake kit and i could use the money else where
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  2. #2 Re: are stainless steel break lines worth it?
    Break or brake?
  3. #3 Re: are stainless steel break lines worth it?
    Oct 2011
    Michigan
    brake? you know what i mean but really do i NEED them?
  4. #4 Re: are stainless steel break lines worth it?
    You need the right length.
    But stainless or not doesnt mean ****.
  5. #5 Re: are stainless steel break lines worth it?
    Willoughby, Ohio
    i just bent the bracket out a lil to give the stock lines more play, only reason you would 'need' them is because they are longer, so i just made mine reach for free.99
  6. #6 Re: are stainless steel break lines worth it?
    Oct 2011
    Michigan
    your talking about the bracket on the car where the rubber line meets the metal line? you just angled that a little and it worked well for you?
  7. #7 Re: are stainless steel break lines worth it?
    Willoughby, Ohio
    yes on the inside wheel well, all you need is like an inch, i bent them out a little with no problems...on 2 cars actually
  8. #8 Re: are stainless steel break lines worth it?
    Oct 2011
    Michigan
    ok sweet ill try that! maybe get SS lines later on
  9. #9 Re: are stainless steel break lines worth it?
    i bent the tab that holds the line as well. also turn the wheels all the way and reach in there to feel if the line is hitting the tire, if so twist the line one way or the other on the caliper banjo bolt there, to move it away from the tire.
    i had mine set, then got new tires up front and had to move them again.
  10. #10 Re: are stainless steel break lines worth it?
    Oct 2011
    Michigan
    alright ill keep that in mind when i do my 12'' brake upgrade
  1. Stainless steel brake hoses
    By quiksilvergt in forum Brakes/Suspension/Chassis
    Last Post: 10-05-2008, 06:18 PM
