Thread: stock ride height correct half shaft question
Results 1 to 6 of 6
  1. #1 stock ride height correct half shaft question
    GTP Level Member buickman104's Avatar
    NYC
    At stock ride height with full weight on the suspension is the axle supposed to be straight from the trans out to the knuckle or at a slight downward angle? I need to install spacers but need to know the correct angle so i know to install a full or half kit with the spacers.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  2. #2 Re: stock ride height correct half shaft question
    GTP Level Member
    Pittsburgh
    it will be at a slight downhill angle
    2003 SSEi,
  3. #3 Re: stock ride height correct half shaft question
    Charles City, IA
    slight down hill to almost straight.
    SMGPFC Two Nipple General
  4. #4 Re: stock ride height correct half shaft question
    NYC
    Thank you guys. Yesterday i noticed my axles are at an opposite orientation than stock! Time for spacers!
  5. #5 Re: stock ride height correct half shaft question
    Done?
  6. #6 Re: stock ride height correct half shaft question
    NYC
    Added vinnie's spacers full set and that brought my suspension back to stock angle. The car feels so much better.
  1. New ZZP rear springs ride height question (higher than stock)
    By hifi dream in forum Brakes/Suspension/Chassis
    Last Post: 05-23-2012, 10:49 AM
  2. performance springs with stock ride height?
    By jdmgtp in forum Brakes/Suspension/Chassis
    Last Post: 11-10-2011, 09:04 AM
  3. Stock Ride Height - 04 GP
    By jmoore4294 in forum Brakes/Suspension/Chassis
    Last Post: 07-20-2011, 07:07 PM
  4. Stock ride height struts/springs
    By Phyrstorm in forum Brakes/Suspension/Chassis
    Last Post: 06-29-2010, 04:11 PM
  5. half shaft cause abs/tcs light?
    By LAIDBACKLUKE in forum Brakes/Suspension/Chassis
    Last Post: 01-29-2010, 08:17 AM
