Thread: F-body brakes?
Page 1 of 5 123 ... LastLast
Results 1 to 20 of 82
  1. #1 F-body brakes?
    Jul 2008
    Poteau Oklahoma
    If you use the f-body calipers do you also use the rotor? Front and back!?!?!? What would the smallest tire/wheel combo you could use?
    Just asking so I can put these notes in my little book. I couldnt find much on this in the how-to section.
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  2. #2 Re: F-body brakes?
    Barksdale AFB, LA
    Quote Originally Posted by justwhisen View Post
    Yes. The F-body calipers are designed for a 12" rotor vs your 11" rotor.
    The F-body upgrade is only for the front.
    16" rims are the smallest that will fit.
    2009 Subaru Impreza WRX STI
  3. #3 Re: F-body brakes?
    Jul 2008
    Poteau Oklahoma
    ok. why not the rear? are the calipers the same size? and just to clarify, I can use my stock wheels with this upgrade?
    yea yea yea I know. shut up right.
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  4. #4 Re: F-body brakes?
    Jul 2008
    Poteau Oklahoma
    saber are you still at home?
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  5. #5 Re: F-body brakes?
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    Quote Originally Posted by Sabrewings View Post
    The honey comb 16' will NOT fit
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  6. #6 Re: F-body brakes?
    Jul 2008
    Poteau Oklahoma
    I have the torque stars.
    <<<< blue car
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  7. #7 Re: F-body brakes?
    Barksdale AFB, LA
    If you really want to do the rears, I guess you can. Most of your braking is done up front and the few who did the rears didn't notice a difference.
    Quote Originally Posted by Toofastgs View Post
    Being unfamiliar with GPs, I didn't know that. All Imp wheels fit.
  8. #8 Re: F-body brakes?
    Wichita, KS
    Many wheels will work, only stock wheels we know will not clear are these:
    But these cross lace wheels will:
    16x8 in size. These make awesome drag rims.
    ~F~
  9. #9 Re: F-body brakes?
    Greensburg, PA
    First off the torque stars will fit cuz thats what i was running for a while and second of all if u want to do a rear brake upgrade there are 2 options a GXP swap or the bear big brake upgrade. Both over priced new for what they do but if you can find a GXP rear setup at a junkyard for under 300 id def do it. Stopping improves some, not a bunch but i still noticed a difference,and it looks amazing with 12" rotors all around.
    Mods:3.4 pulley + recommended mods/ F-Body Front & rear GXP Calipers/ GMPP handling upgrade kit + otto strut brace/ SSC Gen 1 Springs on GR-2 struts/ Verde 5 18x8 Rims
  10. #10 Re: F-body brakes?
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Quote Originally Posted by bula81069 View Post
    Did you use a Grand Prix GXP or a Bonneville GXP? Anything I have looked at for the Grand Prix GXP shows 11" rotors, which is the same as stock. The Bonneville GXP has 12" rotors, though. So is it a direct swap? Do you have to replace the brackets?
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  11. #11 Re: F-body brakes?
    Greensburg, PA
    Well grand prix GXP have 11.7" rotors while stock are 10.9. Its the same kit that the w-body store sells. the rear GXP caliper clears the rim by about 2 mm maybe 3.
  12. #12 Re: F-body brakes?
    Waynesboro, PA
    In the rear? What year?
  13. #13 Re: F-body brakes?
    Greensburg, PA
    In 2005 is when the GP GXP came out and it ran until 2008. so between 2005 and 2008 and yes that is the rear setup. A lot of times I've noticed on junk yards they've listed the part as a GXP but I've called and they listed it wrong. It jus takes some time an research to try to find a set from a junkyard and you might have to buy the front and rear all together. The fronts are a 12.7" rotor and require a 17" rim to run them but it still should be cheaper to buy the front and back then sell the fronts if you don't run 17"s year round. Thats actually what I did.
  14. #14 Re: F-body brakes?
    Waynesboro, PA
    Huh, RockAuto and everywhere else I have looked shows a 10.6" rear rotor for the GXP's.
  15. #15 Re: F-body brakes?
    Greensburg, PA
    Thats because rock auto and every other parts warehouse stocks the wrong part. Theres actually a post about that on clubgp lol. You just have to trust me on this one. Don't go to an auto parts warehouse off the internet unless its GMPartsDirect or the W-body store for this setup. Or of course look on car-parts.com and call the junk yard before you order the part.
  16. #16 Re: F-body brakes?
    Greensburg, PA
    Also another easy way to tell if its actually a GXP rotor and caliper is all stock rotors for that car are drilled and the calipers are made by PBR.
  17. #17 Re: F-body brakes?
    GT Level Member riceburner's Avatar
    Aug 2008
    denver, co
    so what is needed to convert to the F-body fronts? other than the rotors and calipers?
    might pull the brakes off the bird since it is not moving
  18. #18 Re: F-body brakes?
    Oklahoma
    Are there any improvements or is it otherwise worth it to upgrade the rears on a GTP with the GXP set up? What are the differences between the two set ups? I take it by your comment that the rear GXP brakes can be run on the GTP without having to go to larger wheels?
  19. #19 Re: F-body brakes?
    Greensburg, PA
    Sorry i havn't been keeping u on this school works been killing me but for the fbody question here's the answer
    McMaster-Carr
    Part# 6679K16 Desc: Metric Steel-Backed PTFE-Coated Brnz Bearing for 12 mm Shaft Diameter, 15 mm Length Price: $2.45/each Qty: 4
    and that's it. heres an instal write up.
    ClubGP Message Forum troubleshooting
    MAKE SURE ITS FROM A 98-02 F-BODY
  20. #20 Re: F-body brakes?
    Greensburg, PA
    There are improvements. rear gxp can be run with the torque stars, crosslance is a no, Im actually running the torque stars and it u want a pic of the clearance i can do that let me know. The price of 600 at the wbody store in my opinion is not worth the it for the improvement you get but if u can find it for like 300 it is. also front GXP rotor is a 12.7 inch and will not fit stock rims. it requires a 17" one. hope this helps
  1. What rear brakes fit?
    By Berger in forum Brakes/Suspension/Chassis
    Last Post: 07-29-2008, 11:46 AM
  2. problem with R1 concepts brakes?
    By Euro in forum Brakes/Suspension/Chassis
    Last Post: 07-11-2008, 09:39 PM
  3. Major loss to the G-body/W-body community
    By Sabrewings in forum Off Topic Discussion
    Last Post: 05-21-2008, 03:47 PM
  4. Powdercoating brakes/mounts [*]
    By kyle99gtp in forum How To Write-Ups/Tech Tips
    Last Post: 12-17-2007, 03:41 PM
