Thread: Poly control arm bushings??
Results 1 to 3 of 3
  1. #1 Poly control arm bushings??
    Quincy, Mass
    i know zzp has the ones for the rear bushings but where can i find ones for the front bushings?
    No more GP 04 Impala SS Indy:
  2. #2 Re: Poly control arm bushings??
    Portland Oregon
    No one makes them that I know of. There needs to be a decent amount of flex in the fronts to deal with up/down movement of the suspension.
  3. #3 Re: Poly control arm bushings??
    GTX Level Member Doug 97 gtp's Avatar
    Sep 2011
    palm harbor florida
    just get some moog bushings they are alot stiffer the the stock ones.
    1997 GTP . repainted in jet black with blue pearl. rebuilt motor
    with vs cam ported heads and blower.
  1. Poly sway bar bushings for GMPP handling kit
    By crbquist in forum Brakes/Suspension/Chassis
    Last Post: 05-16-2011, 11:57 AM
  2. Poly Sway Bar Bushings
    By 2000SILVERSE3800 in forum Brakes/Suspension/Chassis
    Last Post: 05-01-2011, 04:20 AM
  3. need LCA's/bushings but want poly bushings...
    By Regalgs98 in forum Brakes/Suspension/Chassis
    Last Post: 01-14-2011, 09:24 PM
  4. Poly control arm bushings?
    By Golgo13 in forum General Tech Discussion
    Last Post: 10-20-2010, 05:06 PM
