Thread: Brake Ticking?? new pads, no change.. WTF!!
Results 1 to 20 of 22
  1. #1 Brake Ticking?? new pads, no change.. WTF!!
    GTP Level Member
    Nov 2011
    Kansas
    I noticed today while driving that when I hit my brakes I hear a slight ticking. As the car slows down so do the ticking. It sounds like a card in bicycle spokes. It doesnt do it on acceleration, turning, coasting, etc. Only while braking. Does anyone have any ideas of what this may be?
  2. #2 Re: Brake Ticking??
    Check all the parts. You don't mention if you looked it over yet.
  3. #3 Re: Brake Ticking??
    GTP Level Member
    Nov 2011
    Kansas
    I am hoping to pull tires tonight and get a better look at it.
  4. #4 Re: Brake Ticking??
    Ok.. check those little metal pieces that hold the pad, check the rotors, look it all over and likely you'll find it.
  5. #5 Re: Brake Ticking??
    GTP Level Member
    Nov 2011
    Kansas
    They are sending me new pads. So I will wait to tear into the car until I get those. Should be a weekend project.
  6. #6 Re: Brake Ticking?? new pads, no change.. WTF!!
    GTP Level Member
    Nov 2011
    Kansas
    Changed the pads today, made sure the clips and brackets were all correct (from what I could tell) and it is still doing it. ?
    Is there something else that can cause this issue? I think it is only during braking, it definitely gets louder when applying the brakes.
    Any other thoughts?
  7. #7 Re: Brake Ticking?? new pads, no change.. WTF!!
    GTP Level Member
    Nov 2011
    Kansas
    They are sending me new front rotors now lol. If that doesnt fix it, then I guess the car will be going to the shop.
  8. #8 Re: Brake Ticking?? new pads, no change.. WTF!!
    Donating User Odi's Avatar
    Chicago South Suburbs
    stuid question, do you use that brake pad grease or whatever ur suppose to grease the backside of the pad with?
  9. #9 Re: Brake Ticking?? new pads, no change.. WTF!!
    GTP Level Member
    Nov 2011
    Kansas
    Stupid answer... no lol. I never had, and have never had problems. New rotors are coming my way.
  10. #10 Re: Brake Ticking?? new pads, no change.. WTF!!
    Dec 2008
    STL
    Drilled and slotted rotors? or just stock replacements?
  11. #11 Re: Brake Ticking?? new pads, no change.. WTF!!
    Kansas
    Drilled and slotted.
  12. #12 Re: Brake Ticking?? new pads, no change.. WTF!!
    Dec 2008
    STL
    I figured cross drilled and slotted. I've experienced and heard the same thing on a couple of different vehicles. The "card in bicycle spokes" analogy is exactly how i would explain it. Probably only noticable when you are next to something that reflects the sound like a fence or building otherwise you can hardly notice it just driving on the streets?
    This is normal and I wouldn't worry.
    I'm surprised the company is sending you new parts based on the symptoms. It is very common.
  13. #13 Re: Brake Ticking?? new pads, no change.. WTF!!
    GTP Level Member
    Nov 2011
    Kansas
    Well, I got new front pads and rotors out of the deal haha. I only hear it with the radio and windows down lol. So I will put new parts on and go from there lol. And I can hear it regardless of where my car is.
  14. #14 Re: Brake Ticking?? new pads, no change.. WTF!!
    I'm wondering if you even put the D&S'ed rotors on correctly...lol
  15. #15 Re: Brake Ticking?? new pads, no change.. WTF!!
    GTP Level Member
    Nov 2011
    Kansas
    Yes, I am not that stupid. They are directional. And hadnt always made that noise.
  16. #16 Re: Brake Ticking?? new pads, no change.. WTF!!
    May 2012
    Iowa City, Iowa
    Just a thought-don't know anything about the emergency brakes in these cars as it's my first GM ever. But I had an 03 Ford F-150 that had same issue. Turned out to be the emergency brake pad in the rear had completely fallen off the metal and was ticking on the inside of the brake rotor. Like I said, I don't know how these e brakes work, but with the F-150 the emergency brake shoe was on the inside of the rear rotor. So just something to check if you haven't found it yet....
  17. #17 Re: Brake Ticking?? new pads, no change.. WTF!!
    GTP Level Member
    Nov 2011
    Kansas
    I need to pull the rear tires still. I was thinking something with the E-Brake.
  18. #18 Re: Brake Ticking?? new pads, no change.. WTF!!
    jack the car up and spin the back wheels to see if it makes the noise, before you take it all apart, once the tire is off everything is loose and it could be hard to hear anything.
    applying the regular brakes has nothing to do with the e brake though.
    the E brake looks like a set of old style drum brakes, you have a star wheel to adjust them in or out as needed., or you could have a busted spring that holds the e brake shoes in place.
    to get to the e brake you need to take off the caliper bracket then the rotor, and they are inside the back of the rotor bolted to the backing plate.
    this has been going on for some time now hasn't it? good luck getting it found. friggin gremlins suck.
  19. #19 Re: Brake Ticking?? new pads, no change.. WTF!!
    GT Level Member RyanL's Avatar
    Montreal, Quebec, Canada
    also check and make sure your pads are not loose inside the bracked. try to rotate them, if there is play then the pads are the cause this does happen a lot. also if it is too tough to insert or remove the pads this could be casusing it aswell. the ticking noises usually come from the pads moving around inside the shims.
  20. #20 Re: Brake Ticking?? new pads, no change.. WTF!!
    also the caliper bolts, take them out and clean them and the bolt hole they go in, flush it out with brake cleaner, and re grease with synthetic brake grease, autozone sells in little ketchup packs at the register. ( work the grease into the hole with the caliper bolt, use plenty of grease) and grease where the pads hook into the caliper bracket as well, do this for all 4 brakes.
  1. best brake pads.... Lets have some fun
    By bigtom9492 in forum Brakes/Suspension/Chassis
    Last Post: 07-14-2010, 10:55 PM
  2. park brake pads?
    By 1BlwnGTP in forum Brakes/Suspension/Chassis
    Last Post: 05-12-2010, 07:29 PM
  3. Brake Pads and rotors
    By packerfanjc in forum General Tech Discussion
    Last Post: 01-20-2010, 09:49 PM
  4. recommend brake pads
    By nemesis in forum Brakes/Suspension/Chassis
    Last Post: 07-23-2009, 08:52 PM
