da fack is this noise? its horible. i want people turning heads at the blower not that pos noise. rear driveside
VID_20120305_190220.mp4 video by 1gt420 - Photobucket
The video isn't very good but it sounds like your brake shield is rubbing the rotor.
pull the wheels off and check your brakes, the slider pins may be dry and the pads are dragging the rotor a bit, or maybe the e brake is out of whack and hitting the drum part of the rotor. could even be the squealers on the brake pads if you are out of pads.
