Thread: Loud clunk in driver side rear
Results 1 to 6 of 6
  1. #1 Loud clunk in driver side rear
    Becca Boo MizzBecca's Avatar
    Michigan
    my friend has a 99 gt coupe, and everytime she hits a bump or does a sharp turn the driver side rear has a big clunk.. its not her springs but i'm not sure what else it could be. any answers would be appreciated.
    I drive a POS
  2. #2 Re: Loud clunk in driver side rear
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    check the strut mount in the trunk.
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  3. #3 Re: Loud clunk in driver side rear
    Dec 2008
    Indianapolis, IN
    Check the track bar, too. Both myself and my mechanics could not find it as the problem until it was totally broken. See below.
    http://www.grandprixforums.net/rear-...tml#post627283
  4. #4 Re: Loud clunk in driver side rear
    Michigan
    Quote Originally Posted by Teancum View Post
    Can I see that from just looking closely underneath the car? It wasn't her strut mounts so is it possible it could be due to her tie rods or ball joints? (I'm def not good with suspension sorry)
    I drive a POS
  5. #5 Re: Loud clunk in driver side rear
    SE Level Member Burley117's Avatar
    Nov 2011
    Kalamazoo, MI
    Check the U-clamp that fixes the stabilizer bar to the frame. A friend of mine had one loose and directional changes or rapid braking caused it to clunk against the frame....cheap fix if that's it.
    06 Grand Prix, 01 Grand Prix GT, 98 Grand Prix GT, 98 GrandPrix GTP
  6. #6 Re: Loud clunk in driver side rear
    Dec 2008
    Indianapolis, IN
    Quote Originally Posted by MizzBecca View Post
    Sortof -- I didn't find mine until it was too late, but shake the track bar (it goes from the center of the car down at a slight angle to the wheel) both on the ground and jacked up.
  1. Rear driver-side window
    By VejGTP in forum 04+ Specifics
    Last Post: 10-14-2011, 01:02 PM
  2. Front Driver Side "Clunk" Mystery. Any ideas?
    By nickbuol in forum Brakes/Suspension/Chassis
    Last Post: 05-10-2011, 03:41 PM
