Hey lately I have been hear a constant clicking noise when I apply the brakes coming from my rear wheels. Any ideas? Gonna check it Tomor. Just wanted some pointers.
Any help is appreciated. Thanks.
It may be the shoes…just a suggestion, not a diagnosis. You may want to have a certified technician do a quick inspection to be sure.
Keep us posted.
Louis
GM Customer Service
remove the back wheel and check the pads, you may be down to almost metal or 1/2 a pad wore thin and broke off, or the squealers are hitting the rotor.
hows your pedal feel, is going low? is the master cylinder low on fluid? all sings of worn pads.
clean up the pin and hole it goes in with brake cleaner, then re grease em.
i greased my fronts 2 times and they kept squealing, till i cleaned them all up nicey nice. then greased them again.
