Thread: Polyurethane bushings concerns!! Help
Results 1 to 20 of 27
  1. #1 Polyurethane bushings concerns!! Help
    Calgary
    so i was on zzp and noticed i can replace all my bushigns with poly bushigns including sway bar bushings. i want to do this but just want to know of any pros or cons to doing this or if there is any increased wear on my car?
    i am planning on doing the upper engine mounts, dog bones, all sway bar bushings and links, lower engine mount, tranny mount, ann control arms. also planning on doing trailing arms and all latteral arms and adding in some strut tower braces to really improve the suspension. pretty much any poly bushings i can get i am doing.
    i have already replaced most of the suspension parts and drivetrain parts like the cv axles ball joints and tie rods...
    anyone have any ideas??? pros or cons???
    THANKS!
  2. #2 Re: Polyurethane bushings concerns!! Help
    Charles City, IA
    Your car will shake a lot, but the engine wont move, and put slightly more power on the ground.
    SMGPFC Two Nipple General
  3. #3 Re: Polyurethane bushings concerns!! Help
    Calgary
    on a scale of 1 - 10 what would you consider a lot of shaking? im okay with it really as a drive a 1981 camaro with a big block that shakes a lot. kind of gives it that muscle car feel.... will the poly bushings but any extra wear on any other items in my car???? thanks.
    It doesn't shake a lot. You'll notice it, but its not bad.
    Ohio
    If you have poly bushings all over the board, then it won't shake too much. And it'll subside over time
    Sent from my DROIDX using Tapatalk
  6. #6 Re: Polyurethane bushings concerns!! Help
    Pennsylvania
    On a scale of one to Michael J. Fox, I'd say it would put you somewhere in the realm of a coin-operated massage chair.
  7. #7 Re: Polyurethane bushings concerns!! Help
    If you are a pretty stock setup, I'd suggest the following
    Regular motor and trans mounts, no need for poly
    Poly mounts at the front of the radiator support (square ones)
    Regular dogbones
    That'll keep your engine vibration reasonable. A lot of guys like Buickman104 and myself etc changed the radiator and dogbones to poly and regretted it. I've driven a couple of cars with the poly lower mounts (engine/trans) and it amplifies the vibration even more. This is a big power mod that isn't needed on a reasonable car.
    As for suspension, I'd poly the heck out of everything. You'll love the way it drives after that. Doesn't stress other things, just firms it up and makes it handle.
  8. #8 Re: Polyurethane bushings concerns!! Help
    Poly everywhere?
    Your dentist will love you.
    When it vibrates all of your fillings out.
    And your leg goes numb driving on the highway for more than 10 minutes.
    Ask my anchor when I drove to Iowa, with no cruise control...aka...my right leg. I used my hip to control the pedal...since I nearly had nerve damage after that trip.
    Proes? Dat injen nevah moovs. Et poots powah 2 teh groawnd lik no 1ez biznaz
  9. #9 Re: Polyurethane bushings concerns!! Help
    GT Level Member MBruneaux's Avatar
    Canterbury, CT
    As far as upper engine mounts I flipped the big end and poly small ends. Definitely nicer and firmer without being too harsh, as mentioned before it will subside a little or you get used to it..
    2001 Grand Prix GTP - Daily Driver12" front brake upgrade ('05 Monte), Raptor tune, Open cone, Front and rear strut tower braces, SS brake hoses, BMR trailing arms, ZZP 3" catted downpipe, Dorman front sway bar, GMPP rear sway bar, solid trans and engine mount, flipped dog bones and Borla exhaust.
  10. #10 Re: Polyurethane bushings concerns!! Help
    with a cam perhaps.
    stock cam its pretty unnoticeable
  11. #11 Re: Polyurethane bushings concerns!! Help
    GTP Level Member buickman104's Avatar
    NYC
    Regular dogbones
    Agreed with Bill. My vibration was bad enough that I could hear the window regulator cables rattle around inside.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
    Ohio
    with a cam perhaps.
    With the stock cam the vibration was pretty dam noticeable. Like I said though, it goes away after awhile
  13. #13 Re: Polyurethane bushings concerns!! Help
    It doesn't go away..you learned to tolerate it.
  14. #14 Re: Polyurethane bushings concerns!! Help
    Poly rad side here, stock for the rest
    It's not bad at all.
  15. #15 Re: Polyurethane bushings concerns!! Help
    Ohio
    yeah youre probably right bill. but yeah i have full upper polys, rad and bones
  16. #16 Re: Polyurethane bushings concerns!! Help
    I know I'm right.. you got rattled and now you probably even have the jitters when you walk... lol
  17. #17 Re: Polyurethane bushings concerns!! Help
    Ohio
    lol sometimes...its fun though whenever i got a chick in the car and i open the cutout and go wot....i gotta ask if her lips quiver lol
  18. #18 Re: Polyurethane bushings concerns!! Help
    Pennsylvania
    Quote Originally Posted by 99pgpgt View Post
    You have vibration at WOT?
  19. #19 Re: Polyurethane bushings concerns!! Help
  20. #20
    Bunnell, FL
    Open downpipe ftw. So how does poly compare to open Dp?
    Kindle Fire: The Keyboard Sucks, So Please Forgive Mass Misspelling
    I'm a Sex Offender
  1. 2000 gtp issues, concerns.
    By 3CLiPSE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-22-2011, 04:50 PM
  2. Polyurethane motor mounts
    By PALMCASTER GT1 in forum General Tech Discussion
    Last Post: 03-11-2011, 08:27 AM
  3. a few questions, and concerns
    By blowngt84 in forum General Tech Discussion
    Last Post: 07-24-2008, 06:06 AM
  4. Newbie with concerns
    By evlprx in forum Introductions/Noob Questions
    Last Post: 01-31-2008, 02:33 AM
