Thread: 93 grand prix front subframe bushings
Results 1 to 2 of 2
  1. #1 93 grand prix front subframe bushings
    Jan 2012
    Hebron, Indiana, United States
    Do I need a hydraulic press to press the bushings together or can i just use a bottle jack from underneath. Its the back two bushings on the subframe FWD(if that helps). Basically is there any way to do it without completely removing the subframe?
  2. #2 Re: 93 grand prix front subframe bushings
    get the car in the air, and put a jack under the middle of the back part of the cradle, remove the 2 18mm bolts lower the jack like 2 inches or so, then slide the bushing out, and replace, jack the cradle back up and bolt it up.
  1. need to find subframe bushings...
    By sheffy in forum Brakes/Suspension/Chassis
    Last Post: 02-14-2013, 09:16 PM
  2. subframe bushings??
    By nicks98gtp in forum Brakes/Suspension/Chassis
    Last Post: 03-11-2011, 09:54 PM
  3. 1990 Grand Prix Prothane bushings....
    By nissanboy86 in forum Brakes/Suspension/Chassis
    Last Post: 09-19-2009, 11:21 PM
  4. Front Control Arm Bushings
    By 2001camaroB4C in forum Brakes/Suspension/Chassis
    Last Post: 11-23-2008, 01:38 PM
