Thread: springs and struts
Results 1 to 20 of 33
  1. #1 springs and struts
    Jun 2011
    Putting in zzp lowering springs and was wondering if i could leave the stock struts in or if i should switch them out with kyb gr2/excel g struts? Are they worth it or the stock ones fine?
  2. #2 Re: springs and struts
    how many miles on your stock struts? Chances are they are close to shot anyway and need changed so might as well change them because those springs will likely finish them of shortly.
  3. #3 Re: springs and struts
    Jun 2011
    Close to 180k. I got the car with 170kish miles on it so idk if they were changed before that.
  4. #4 Re: springs and struts
    Put new ones on since your swapping springs anyway ans enjoy your new ride.
  5. #5 Re: springs and struts
    Jun 2011
    Aight cool. Are the kyb ones good or should i get something else? I cant afford the adjustable ones so something around 200 or less would be good
  6. #6 Re: springs and struts
    Omaha, NE
    Stock are fine, they will wear a little faster than aftermarket or new stock would.
  7. #7 Re: springs and struts
    pogo city if you dont.
    And by zzp you mean ssc?
  8. #8 Re: springs and struts
    Bunnell, FL
    if you bought them from zzp you overpaid by 100$
    I'm a Sex Offender
  9. #9 Re: springs and struts
    Jun 2011
    I havent bought them yet. I looked around at a couple other sites like 3800 performance and they sell the springs for roughly the same price. If you know a place that sells them cheaper it would be greatly appreciated.
  10. #10 Re: springs and struts
    says the guy who doesnt drive his lowered car.
    youll go through a set of struts in 20k miles if you have springs with higher spring rates than stock.
  11. #11 Re: springs and struts
    Jun 2011
    So what struts should I put in so that doesn't happen?
  12. #12 Re: springs and struts
    I lowered mine and put the gt2 struts in about 2 years ago... been doin fine since then... its all a matter of personal preference really ad all will have different driving styles...
    personally I drove one with the adjustable springs and other than the ride being a little smoother, performance wise there wasn much difference between the adjustable type and gt2s
  13. #13 Re: springs and struts
    Jun 2011
    I asked the people on ssc how much for a set of 4 and they said its 200 including the shipping. the front drop 1.8" and the back is 1.6" should i get them or the ones from zzp?
  14. #14 Re: springs and struts
    the springs zzp sells ARE ssc springs. buy them wherever you can get them cheapest.
    i personally dont like the spring rates versus the drop and think they ride too harsh for the drop they give.
  15. #15 Re: springs and struts
    Jun 2011
    Are there springs that don't lower the car but are better than the stock?
  16. #16 Re: springs and struts
    the only spring youre going to find that doesnt lower the car that much and is still an improvement are vogtland springs. they are the original manufacturer of the GMPP springs used on their upgraded suspension before they discontinued it.
    however, at this point in time you're going to have a hard time tracking a set down. they seem to fly off the shelves anytime they are produced.
  17. #17 Re: springs and struts
    Jun 2011
    I just checked the vogtland site and they sell lowering springs for 230 and the drop is 1.4" should I get those instead or the ssc ones?
  18. #18 Re: springs and struts
    if youd like to keep the stock ride quality, or close to it, yes i would go for those.
  19. #19 Re: springs and struts
    Jun 2011
    aight cool. so ill save up for those. are the kyb sturts good with these or should i try and get something else?
  20. #20 Re: springs and struts
  1. Struts and springs
    By Timmi in forum Shops and Community Heroes
    Last Post: 03-23-2010, 02:49 PM
  2. 04+ struts & springs
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 09-03-2009, 04:21 PM
  3. Looking for new Struts, maybe springs also
    By xawahl in forum Brakes/Suspension/Chassis
    Last Post: 03-14-2009, 06:02 PM
