Thread: Red or Blue Threadlocker for Axle Hub Bearing Mounting Bolts?
Results 1 to 10 of 10
  1. #1 Red or Blue Threadlocker for Axle Hub Bearing Mounting Bolts?
    Dec 2011
    Cliffside Park, NJ
    Do I use red or blue threadlocker when reinstalling the three front axle hub bearing mounting bolts? Thanks!
  2. #2 Re: Red or Blue Threadlocker for Axle Hub Bearing Mounting Bolts?
    Omaha, NE
    I don't think it requires any if properly torqued...
  3. #3 Re: Red or Blue Threadlocker for Axle Hub Bearing Mounting Bolts?
    Dec 2011
    Cliffside Park, NJ
    New factory hub mounting bolts seem to have red threadlocker RMS Product Details: 11570580 - Hub Bolt but I've also seen videos where blue threadlocker is used. This will be my first hub replacement.
  4. #4 Re: Red or Blue Threadlocker for Axle Hub Bearing Mounting Bolts?
    none, just make them tight and they wont ever come loose.
  5. #5 Re: Red or Blue Threadlocker for Axle Hub Bearing Mounting Bolts?
    GTX Level Member real diehl's Avatar
    Salina, KS
    tighten them
  6. #6 Re: Red or Blue Threadlocker for Axle Hub Bearing Mounting Bolts?
    Don't use any if you want to get them off ever again. Being a W body..you'll need to get them off again...
  7. #7 Re: Red or Blue Threadlocker for Axle Hub Bearing Mounting Bolts?
    May 2011
    winnipeg
    [never use red unless it is for permanent install, you need heat to remove it if using red threadlocker
    QUOTE=GT997;712378]Do I use red or blue threadlocker when reinstalling the three front axle hub bearing mounting bolts? Thanks![/QUOTE]
  8. #8 Re: Red or Blue Threadlocker for Axle Hub Bearing Mounting Bolts?
    Charles City, IA
    blue is fine, I normally dont use any tho. dont use red or you will need a torch to get them out.
    SMGPFC Two Nipple General
  9. #9 Re: Red or Blue Threadlocker for Axle Hub Bearing Mounting Bolts?
    Jan 2009
    Tallahassee, FL
    Locktite won't hurt, if you ever want to get the nut back off don't use the red lol
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  10. #10 Re: Red or Blue Threadlocker for Axle Hub Bearing Mounting Bolts?
    Jan 2012
    FT Campbell, KY
    Red is pretty much permanent. Torque it right and forget it. You WILL be replacing your hubs again, anyway, might as well not make it impossible on your self.
    Colleen
    : CAI, HV3, 2.5" d/p w/h/f cat. Full suspension, PowerSlots w/Hawk HPS, GR2s, Sonar projectors. Needs tune. Awaiting install of FBod brakes.
    Shianne: 98 L36 MM5. Good start to a LONG project.
  1. Torque Spec for wheel bearing and Axle Nuts
    By bjornbjorn in forum General Tech Discussion
    Last Post: 08-11-2014, 12:11 PM
  2. GMB Axle Bearing Hub Assemblies?
    By GT997 in forum Brakes/Suspension/Chassis
    Last Post: 12-24-2011, 04:40 PM
  3. Difficulty of CV axle and main bearing replacement?
    By gtpyceout in forum General Tech Discussion
    Last Post: 08-14-2011, 02:17 AM
  4. arp head bolts or tty bolts?
    By Lacboi in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-12-2011, 10:51 AM
  5. Lower strut mounting bolts-- where to buy?
    By lightheat in forum Brakes/Suspension/Chassis
    Last Post: 08-01-2010, 08:56 PM
