Thread: Lowering 04+ GP
Results 1 to 8 of 8
  1. #1 Lowering 04+ GP
    SE Level Member The_Avenger's Avatar
    Ontario, Canada
    Hey I was wondering about lowering my GP. I wanted to go with Eibachs but on their site/3800P it says they only work on the 97-03's. I am also kinda confused on the whole strut setup. I would want to replace the struts as well and remember someone mentioning which struts are best for lower applications.
    Pretty much I am just looking for a walk through/options on lowering as I am pretty new to this stuff.
    I want to drop about 1.2-1.5". Anybody out there willing to walk me through this that would be fantastic.
    2004 Grand Prix GT - 75xxxkm - Inferno Package (no hood), Wizaired CAI, ZZP Strut Tower Brace, 180 T-Stat, Throttle Body Heat Shield, more to come...
  2. #2 Re: Lowering 04+ GP
    St. Louis Mo.
    I do believe most 04's with the exception of the Comp G's will accept most things from the 03 range of products. The Comp G struts and springs you dont want to mess with really cause they are already darn good. I believe with most certainty the KYB AGXs and probably GR2's will work with the 04's. You could always check out the SSC Gen II's or even ask Will Overkill about the possibility of them fitting your 04. The SSC Gen II's will only drop about 1 1/4 to maybe 1 1/2 inches. They are not drastic by any means but will add a noticeable difference to the look of your ride. Also I do believe the SSC's are made out of Canada
    Just some thoughts for ya
    James Shafer
    St. Louis MO
  3. #3 Re: Lowering 04+ GP
    Ontario, Canada
    Thanks for the reply, I will have to check them out and bonus for not paying damn duty charges form the US!
  4. #4 Re: Lowering 04+ GP
    St. Louis Mo.
    Here is there site if you cant find them anywhere else. I do believe Will Overkill sells them, or use to sell them up in Canada.
    Superior Sport Chassis Inc. - Home
    Here are the specs for the 04 GP's
    Grand Prix 04-05 24-5221 1.70 1.70
    James Shafer
    St. Louis MO
  5. #5 Re: Lowering 04+ GP
    SE Level Member WillOverkill's Avatar
    Feb 2008
    2004+ SSC springs are a terrible drop, saggy rear end.
    We mix and match SSC springs from several different W-Body applications to get the drop you want :: Overkill Motorsports ::
    Get Your 3800 Overkilled @ http://www.getoverkilled.ca
  6. #6 Re: Lowering 04+ GP
    St. Louis Mo.
    See I knew he would come through!!!
    Thanks for chiming in Will!!!
    James Shafer
    St. Louis MO
  7. #7 Re: Lowering 04+ GP
    GrandPrix Junkie FastKatt's Avatar
    Feb 2008
    Rkrd, IL
    I think I'll be checking the site as well
    No trees were destroyed for this message.
    However, a great number of pixels were extremely inconvenienced.
    2004 Grand Prix Comp-G GTP Mod List - MySpace
  8. #8 Re: Lowering 04+ GP
    Ontario, Canada
    Awesome 100% book marked and ready to go when I get the cash together. Thanks everyone.
  1. lowering kit
    By 08gp in forum Brakes/Suspension/Chassis
    Last Post: 06-01-2008, 09:35 PM
  2. Car shakes after lowering
    By Smokedgtp in forum Brakes/Suspension/Chassis
    Last Post: 04-30-2008, 09:17 PM
  3. lowering springs help
    By philip09 in forum Brakes/Suspension/Chassis
    Last Post: 04-03-2008, 05:50 PM
