Thread: Bad Strut Mount?
Results 1 to 6 of 6
  1. #1 Bad Strut Mount?
    Apr 2011
    Pittsburgh
    Can a bad strut mount cause an abs light to go on? I hear a clicking in the right stut area and when I turn I can hear it. Already have had wheel hubs on both sides doen, new rack and pion, struts are 2 years old. Alignment done a month ago, tires balanced and rotated, new tie rod ends.
  2. #2 Re: Bad Strut Mount?
    no,
    the clicking could be a cv axle.
    scan the car and see exactly what hub is bad, you'll need a ABS scanner.
  3. #3 Re: Bad Strut Mount?
    Charles City, IA
    no, it cant. I would have the codes read and see what sensor is throwing the code and check the firing. and yeah what she said above me.
    SMGPFC Two Nipple General
  4. #4 Re: Bad Strut Mount?
    Omaha, NE
    Make sure your strut mount nuts are tight.
  5. #5 Re: Bad Strut Mount?
    Apr 2011
    Pittsburgh
    Could the abs light go on for a bad strut. I am just trying to make sure it is the cv joints because I am still deciding to either spend the money for the abs scan or use that money for a cv joint. My dad checked the cv joint and said it was fine but can he miss something internally in the joint..
  6. #6 Re: Bad Strut Mount?
    Apr 2011
    Pittsburgh
    Well turned out to be a bad wheel assembly on the driver side. I replaced both on the front like a year ago so I guess I got a cheap one. As for the popping in the strut, I don't know what that is but might need a new strut mount or strut. We will see what happens
  1. Torque mount/strut help
    By ElAlacran2010 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2011, 12:06 AM
  2. Strut mount keeps failing
    By Silver GTP in forum Brakes/Suspension/Chassis
    Last Post: 12-13-2010, 12:37 AM
  3. Need help with with rear strut mount??
    By 99GTP99 in forum General Tech Discussion
    Last Post: 02-18-2010, 08:27 AM
  4. Strut Mount Caps?
    Last Post: 01-09-2010, 11:50 PM
