Thread: Traction Control/Stability System Module
Results 1 to 15 of 15
  1. #1 Traction Control/Stability System Module
    SE Level Member teamfbody's Avatar
    New Orleans/The Woodlands,Tx
    I have a 2005 GTP Comp G and recently the "service traction control & service stability system" light has been coming on, when i drive the car it stumbles then drives normal afterwards,everytime i stop at a light and pull off it stumbles & either the stability active light comes on or the service stability system light comes on and the traction control light is always on is there an indiviual module for both systems or do they operate as one? I really need to know because I need this fixed ASAP
    heres pics of what im talking about^ ^
    **fbodyNATION** GM DIE HARD FAN<br>ZERO TOLERANCE 4 BULLSH*T.....NO PATIENCE 4 HATRED
  2. #2 Re: Traction Control/Stability System Module
    GT Level Member GMCustomerService's Avatar
    Michigan
    I am sorry to hear of your frustration. If the lights stay on, there is something wrong with the traction control or stability system. I strongly encourage you to visit your dealer for service. They should be able to pinpoint the problem and offer a more accurate resolution. Please keep us posted. If you have any further questions, please feel free to contact me.
    Louis
    GM Customer Service
  3. #3 Re: Traction Control/Stability System Module
    maybe a wheel bearing/hub issue and thats tripping the abs/tc lights, get the car scanned for codes.
  4. #4 Re: Traction Control/Stability System Module
    Ohio
    put it on an abs scanner. should cost all of 80. idk whether or not 04+'s have the ebcm problem.
  5. #5 Re: Traction Control/Stability System Module
    Grand Rapids, MI
    Quote Originally Posted by 99PGPGT View Post
    they very much so can have the problem.
    get it scanned like they said. most abs scanners work fine, but in my case i had to go to the dealer and let them put it on a tech II which said ebcm is bad. which makes since that the other abs scanners said "cannot find codes" because if the computer that stores the codes is bad, then of course its not gonna sync up with the scanner. so if you find a local shop with an abs scanner and they say "hm weirdest thing cant even read the codes" then it could be ebcm, to which i recommend modulemaster.
    my bet is on a wheel speed sensor in the hub like they're saying, that's the most common issue. and an easy fix
  6. #6 Re: Traction Control/Stability System Module
    Ohio
    but with the sensor, youll find its easier to fix the whole hub assembly as the sensors are too overpriced and you figure your better off spending alittle more and being even safer
  7. #7 Re: Traction Control/Stability System Module
    Grand Rapids, MI
    tis correct. may i recommend timken and timken only? that seems to be the consensus here. i myself got timken hubs from rockauto (way better price than AZ or something) and they're doing just fine.
  8. #8 Re: Traction Control/Stability System Module
    Ohio
    brandon brandon brandon....lol timken aint the best bearing around anymore. theyre not US made anymore, but rockauto does have kickass prices. i dont even use my employee discount anymore at advance because i have my boss price match everything i buy haha
  9. #9 Re: Traction Control/Stability System Module
    Grand Rapids, MI
    well recommend another brand then. hell idc as long as it fixes the problem.
  10. #10 Re: Traction Control/Stability System Module
    Ohio
    lol any brand honestly. i go with moog but thats cuz i have them in stock all the time.
  11. #11 Re: Traction Control/Stability System Module
    Omaha, NE
    Timken is still make in America as they have been since 1899.
    Timken Company - Wikipedia, the free encyclopedia
    teamFbody, can you describe the stumble a little more in depth?
  12. #12 Re: Traction Control/Stability System Module
    Ohio
    timken is just next door to me lol bout 20 minutes away
  13. #13 Re: Traction Control/Stability System Module
    Oct 2011
    Toledo, OH
    Crazy coincidence. My 05 GTP started doing this same thing today, only my warnings are TCS/ABS since I'm not a comp-g.
    7"
  14. #14 Re: Traction Control/Stability System Module
    Jun 2012
    i have that same problem what was the outcome?
  15. #15 Re: Traction Control/Stability System Module
    Oct 2011
    Toledo, OH
    Quote Originally Posted by David Mcelveen View Post
    Mine was a bad wheel sensor which meant a new bearing hub.
    7"
  1. service power steering abs system traction control warning
    By ltr450tremor in forum General Tech Discussion
    Last Post: 05-06-2011, 10:14 PM
  2. 1998 GTP Electronic Braking/Traction Control Module
    By Luvgrandprix in forum General Tech Discussion
    Last Post: 04-28-2011, 10:24 AM
  3. 1998 GTP Electronic Braking/Traction Control Module
    By Luvgrandprix in forum Introductions/Noob Questions
    Last Post: 04-23-2011, 11:43 AM
  4. abs/traction/stability service lights
    By jackster1234 in forum General Tech Discussion
    Last Post: 11-09-2010, 01:01 AM
  5. Traction control, stability control , abs brakes warnings
    By warren13 in forum General Tech Discussion
    Last Post: 09-18-2010, 06:26 PM
