Hopefully someone can help with this, or give me some ideas...here goes
For about the last 2 months I have had a loud humming noise coming from my front passenger side wheel well. At first it only did it at 35-40mph and then it was gone. The noise did get louder at the previously mentioned speeds, but within the last 2 weeks the noise has gotten MUCH worse. Now at less then 10 mph it makes a loud rubbing/humming sound, and as I get up to higher speeds it gets louder. Between 40-45 mph sounds like my wheel is going to fly off into orbit. Just a very loud whooom whooom whooom sound. Once past 45 it dies down but is still there. As I slow down it goes back through the sounds in reverse as expected. The car rides smooth except for a slight shimmy if I have to stop fast at high speeds.
I replaced hubs and tie rod ends inners and outer 6 months ago. Also, just to rule out my well worn front passenger tire, we rotated it today to the rear drivers side and put 2 new tires up front...to my dismay, IT GOT WORSE. What should I check out here, any ideas?![]()
