Thread: rack and pinion
Results 1 to 11 of 11
  1. #1 rack and pinion
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    i think my steering has gotten looser in my 99' GTP i dint know if its all in my head or what. im new to working on steering and suspension and i was wondering if its possible if my rack and pinion is worn or maybe if its gone out im not sure please help
  2. #2 Re: rack and pinion
    utah
    they do go out, its not un common
  3. #3 Re: rack and pinion
    check your tie rods first, have a friend turn the wheels all the way to one side, so you can see the tie rod, and then with the car off, rock the steering wheel , look to see any slop in the connection. check both sides.
  4. #4 Re: rack and pinion
    Grand Rapids, MI
    also you can pull on the tires with it in the air and see if you have play in any thing. side to side, up and down.
  5. #5 Re: rack and pinion
    Oct 2011
    Michigan
    the outer tie rods are bad i have the parts and was planning on replacing them tomorrow everything else is good as far as i can tell, so that might be the problem? ill update tomorrow after i replace them to see if it got any better
  6. #6 Re: rack and pinion
    when you take the old ones off, just crack the lock bolt, leave it on, put the new one up to the lock nut, tighten it up, go right to an alignment shop, you'll be close but not perfect.
    chances are the steering wheel will be off to one side too, if you don't get an alignment.
  7. #7 Re: rack and pinion
    Oct 2011
    Michigan
    the car already needs an alignment i was planning on doing that soon too but our alignment computer is down at the moment
  8. #8 Re: rack and pinion
    Oct 2011
    Michigan
    alright we did the tie rod ends like 20min ago i havent driven it much its slightly better it might all be in my head though
  9. #9 Re: rack and pinion
    Grand Rapids, MI
    Grand Prixs just simply do not have the tightest steering in the world. so perhaps you didn't that into account?
  10. #10 Re: rack and pinion
    Quote Originally Posted by asite57 View Post
    it will feel all f'ed up till you get it aligned, may feel ok at 25 mph, but on the highway or hard braking, you will notice it dont feel right.
  11. #11 Re: rack and pinion
    Oct 2011
    Michigan
    well the alignment computer is down right now so im gonna try doing it the old way....the long way, and grand prix's have pretty tight steering much better then most cars
  1. rack in pinion
    By 2005GrandPrix in forum Brakes/Suspension/Chassis
    Last Post: 10-25-2011, 04:28 PM
  2. P.S. Rack and pinion? PLEASE HELP!!
    By dwc1435 in forum Brakes/Suspension/Chassis
    Last Post: 02-28-2011, 01:16 PM
  3. rack and pinion
    Last Post: 02-21-2011, 09:53 AM
  4. GTP rack and pinion
    By mikedinthecity in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-26-2010, 12:33 AM
