Thread: rack in pinion
Results 1 to 13 of 13
  1. #1 rack in pinion
    SE Level Member 2005GrandPrix's Avatar
    Pittsburgh, Pa
    has anyone else have this problem i looked on the site really didnt see anythin bout air being in the lines.
    the car got dropped off cuz the rack was leaking they replaced it and lined the car back up all tht was good till they said tht they couldnt bleed all the air outta the lines.....
    the car is making a loud howling and whinning noise just idling and when u turn it gets worse he said just run it for a few days and the air will come out?? how true is tht??
    theres 150 miles on it still the same does it take more driving for it to get all air out.
    its a 05 grand prix
  2. #2 Re: rack in pinion
    I live here. TLSheff's Avatar
    Quote Originally Posted by 2005GrandPrix View Post
    What did they say they replaced???
    Usually the howling noise is a bad P/S Pump... After that much driving there should have been some difference, Check the fluid in the P/S Resevoir and make sure it has plenty. If it would bleed itself out the level will get lower and lower and that may result in the pump whinning more. Or there is another problem all together.
    Sounds like a shady deal to me... no offense if its a family mech or anything, just seen alot of shady deals in my day and this is bringing back bad memories
    check everything you can, if everything seems fine... go back to them and question them on it. If they want repeat business and a good reference they should do something to help.
  3. #3 Re: rack in pinion
    Pittsburgh, Pa
    the whole rack and pinion and said theres air in lines and it would work its self out didnt know how true it was
  4. #4 Re: rack in pinion
    I don't know for sure, but I do know we sell lots of racks at the dealership I work at (i work in parts) and none ever leave making noise, so the techs have to be able to bleed them out properly or you got a bad rack.
  5. #5 Re: rack in pinion
    the proper way to bleed the rack and pump is to with the car off jack the front wheels in the air, and turn the wheels lock to lock 15 to 20 times, check fluid level at 15, add if needed, go 5 more times, mine actually burped up fluid with the air and over flowed to the floor.
    your pump could be bad too, i had both my pump and rack go out at the same time.
  6. #6 Re: rack in pinion
    Pittsburgh, Pa
    well it was just a minor leak so they replaced it under warranty nothing made noise before it went to shop
  7. #7 Re: rack in pinion
    Take it back and tell them to fix it right
  8. #8 Re: rack in pinion
    Aug 2011
    North Jersey
    Im dealing with the same thing. new rack and 2nd new pump in a year. I threw some of that lucas stuff in the car after sucking out the old fluid. still noisy compared to other cars but its better than before
  9. #9 Re: rack in pinion
    my pump started to whine then died, replaced it, and still nothing, did the rack and it all works like a champ, silent too, used a pep boys reman pump. this one Replacement Auto Parts, Replacement Car Parts | Pep Boys
  10. #10 Re: rack in pinion
    Pittsburgh, Pa
    found out they said it was full of fuild i checked it was real low
  11. #11 Re: rack in pinion
    Pittsburgh, Pa
    so tht fixed the problem
  12. #12 Re: rack in pinion
    At least it was an easy fix
  13. #13 Re: rack in pinion
    it must have burped finally...good deal, better than a new pump.
  1. P.S. Rack and pinion? PLEASE HELP!!
    By dwc1435 in forum Brakes/Suspension/Chassis
    Last Post: 02-28-2011, 01:16 PM
  2. rack and pinion
    By 2005GrandPrix in forum Brakes/Suspension/Chassis
    Last Post: 02-21-2011, 09:53 AM
  3. GTP rack and pinion
    By mikedinthecity in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-26-2010, 12:33 AM
