Thread: bagged gp's
Results 1 to 20 of 29
  1. #1 bagged gp's
    Bunnell, FL
    i know there is one "kit" available but dont remember where i saw it
    i don't want the kit just the air struts
    also for those who are bagged what lines, valves, compressors and tanks you running?
    and what's the link for the air struts?
    I'm a Sex Offender
  2. #2 Re: bagged gp's
    this is the only place i have found them:
    http://www.andysautosport.com/pontia...kits/air_lift/
    i think they are too long to go drop sub frame when you part though. you'll have to chop off the mount and move them up a little if that's what you want to do.
  3. #3 Re: bagged gp's
    Bunnell, FL
    it was on a site like airbagit but it def wasnt airbagit
    I'm a Sex Offender
  4. #4 Re: bagged gp's
    Bunnell, FL
    it was easy street air now airlift
    thanks for the info. it was perfect
    I'm a Sex Offender
  5. #5 Re: bagged gp's
    yeah, easy street has turned into air lift.
    however, they dont sell our application anymore. then again, i havent called and asked if they had anything on the shelves or if they would make them. i just havent seen it listed on their site anymore.
    kuntzie has modified easy street struts.
  6. #6 Re: bagged gp's
    Donating Users jmak gtx2's Avatar
    Mableton, GA 30126
    I found a system from AirBagit.com What do you do to get the wheel alignment right with a bagged FWD car? anyone using a bag system on the board?
  7. #7 Re: bagged gp's
    you get your alignment at the height you are most likely to drive it. that's about it.
  8. #8 Re: bagged gp's
    Mableton, GA 30126
    I'm thinking that if I raise the car until until the axel is level on each side and the car is level front to back then get the alignment done it should be close.
    I found that the air bags from airbagit.com with no air in them have a 2" higher fender well in the front as compared to the rear.
  9. #9 Re: bagged gp's
    thats because the fronts dont go any lower without getting modified.
  10. #10 Re: bagged gp's
    michigan
    they don't, i live near them and my roommate has one of their prototype kits so we go there often so they can check it out. i've asked and nagged about it and get shot down every time.
  11. #11 Re: bagged gp's
    that sucks...universal kits are nice and all, but they are a bunch more work..
  12. #12 Re: bagged gp's
    michigan
    yup, there was a patient issue with the old kit, so they quit making them. now they have changed the issue that was at hand but say that the demand isn't there to make the kits again. the Euro market and luxury/VIP style cars is their focus now. they are about to use a roommate's '04 lexus LS400 to mock up a new kit for those so he will be getting his SECOND free airlift kit! and i can't even get them to make a set for just my car.
  13. #13 Re: bagged gp's
    isnt there other kits made for different cars that are close to the w-body,,,just a thought..
    i thought i remembered reading somewhere that a kit for some ford cars are close enough so that it require a tone of fab like the universal kit require
    SMGPFC Member #10
  14. #14 Re: bagged gp's
    GT Level Member kuntzie's Avatar
    Feb 2010
    Kitchener, Ontario, Canada
    i know its a little late but my kit is easy street/ air lift, they have indeed been modified, the subframe lays out right to the ground,
    i personally know of a airbag it kit and they are junk as they use stock length struts, the lowest they go still don't tuck tire at all and struts really won't last at all.
    the air lift kit uses koni adjustable struts iirc, that are about 3.5" shorter then stock, i modified mine more so by about 1" on the bottoms where the strut attaches to the knuckle.
    i could not drive the car straight at all when i installed the bags, had to do an alignment right away.
    i also did a few other things so i could have some nice poke of the tires, i run 285s on the front and 255 rears, i don't know anyone running wider on a street driven car, never mind with bags,
    i also have perfect and by that i mean in spec camber at a 3.5" drop (my ride height)
    fwiw, i bought a sd front lip and i can't put in on my car as it bottoms out to the pavement with it on. i may put some small spacers in the strut towers as it literally 1/16" touching.
    02 Grand Prix GT Intercooled turbo 5-speed 718whp 618wtq @ 21psi 7575 billet, spool valve, custom manifolds, 4" downpipe, 16way adjustable coilovers, 18x9.5 with 275's all around, gxp interior, gxp brakes
    tilton triple disc, custom aluminum flywheel, tilton slave and master, an awful lot more
  15. #15 Re: bagged gp's
    i am going to use UAS airbags. they are hollow right down the middle, so they can slide right over any normal strut. put a set of coilovers sleeves on a set of struts and bam, you now have a bag over coil setup allowing you to dial in your drive and dumped height perfectly. the bags themselves have about a 5" of drop, ~9.5" total full pressure height.
    either way, it will be a little bit more work to piece together than most setups, but it will be 192% worth it in the end.
  16. #16 Re: bagged gp's
    Brightening up your day. Koniig's Avatar
    Jun 2010
    Illinois.
    Quote Originally Posted by kuntzie View Post
    The air lift kit uses koni adjustable struts iirc, that are about 3.5" shorter then stock, i modified mine more so by about 1" on the bottoms where the strut attaches to the knuckle.
    I could not drive the car straight at all when i installed the bags, had to do an alignment right away.
    I also did a few other things so i could have some nice poke of the tires, i run 285s on the front and 255 rears, i don't know anyone running wider on a street driven car, never mind with bags,
    fwiw, i bought a sd front lip and i can't put in on my car as it bottoms out to the pavement with it on. I may put some small spacers in the strut towers as it literally 1/16" touching.
    I'm so jelly. Teach me your ways.
  17. #17 Re: bagged gp's
    Bunnell, FL
    I'm a Sex Offender
  18. #18 Re: bagged gp's
    please do not pay that much. build your own setup for much cheaper with better components. the bags themselves are necessary, but the rest of it can be sourced better outside of that site.
  19. #19 Re: bagged gp's
    Bunnell, FL
    ^^^ i know that. so the bags essentially replace the springs if i'm reading into it correctly?
    I'm a Sex Offender
  20. #20 Re: bagged gp's
  1. 5-speed + turbo + bagged = kuntzie
    By kuntzie in forum Introductions/Noob Questions
    Last Post: 08-07-2012, 08:36 AM
  2. Anyone active with a bagged gp?
    By GAFF in forum Brakes/Suspension/Chassis
    Last Post: 04-07-2010, 08:08 PM
  3. hey new from sask canada w/bagged gtp
    By Smoke in forum Introductions/Noob Questions
    Last Post: 03-31-2010, 02:55 AM
