Thread: rear coilover pics?
Results 1 to 20 of 27
  1. #1 rear coilover pics?
    Donating Users Regalgs98's Avatar
    Aug 2008
    hamilton,oh
    anyone got shots of their rear coilovers off the car? i want to see the tops. plan on making mine sometime soon.
  2. #2 Re: rear coilover pics?
    Long ones are rear
  3. #3 Re: rear coilover pics?
  4. #4 Re: rear coilover pics?
    Aug 2008
    hamilton,oh
    thanks for the pics! anyone think the stock mount is capable of holding a 300-325lb spring? or should i make my own out of 1/4 in or even 10ga?
  5. #5 Re: rear coilover pics?
    stock mount doesnt accept 2.5" diameter springs without the right spring seat.
    i would make your own upper mounts.
  6. #6 Re: rear coilover pics?
    GTP Level Member BlownBigBlock's Avatar
    Apr 2009
    Carlisle PA
    Front upper mounts you can modify the stock mount, it retains the curvature but will require
    ( in my case) some machine shop work. The rear mount we found it easier to start from scratch
    using the stock mount as a model. 3/16" steel is what we used. Machine shop is still the center
    cup for the rears so I can't post any pics yet.
  7. #7 Re: rear coilover pics?
    GTP Level Member tms8582's Avatar
    Washington Michigan
    Is the purpose of coil overs to adjust ride height?
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  8. #8 Re: rear coilover pics?
    Aug 2008
    hamilton,oh
    Quote Originally Posted by tms8582 View Post
    For most thats probably it. Some want to handle which is what i'm after so i'm looking for some stiffer rates or just better setup overall. I plan on keeping power under 300 to the wheels and possibly 5spd swap since i've noticed even my tuned regals transmission hates cornering and applying power when i want.
    Thanks for the help guys! I seen the one person who has done his own and used modified factory front mounts just wasn't sure about the rears. Pretty sure their plastic anyways.
  9. #9 Re: rear coilover pics?
    Minnesota
    Quote Originally Posted by Regalgs98 View Post
    Sounds like you need a LSD more than a 5 speed.
  10. #10 Re: rear coilover pics?
    Aug 2008
    hamilton,oh
    Quote Originally Posted by Pure2sin View Post
    No, it was the way it acted when I was coming out of a corner. Floored it then jumped around atleast 3x then engaged so hard it hurt me...
  11. #11 Re: rear coilover pics?
    torsen from the gmpp catalog is 1900....
  12. #12 Re: rear coilover pics?
    Aug 2008
    hamilton,oh
    wow. That could pay for my sons' preschool and some schooling after that for some time. Or 3 sets of tires. Or redo my entire suspension and new exhaust.
  13. #13 Re: rear coilover pics?
    Coilovers at 1500 just to get started.
    Throw in a set of sway bars other than GMPP and you're basically at 1900.
    Still have the LCA's, trailing arm, lateral arms, tie rods etc.
  14. #14 Re: rear coilover pics?
    Aug 2008
    hamilton,oh
    who said i was buying a coilover kit? i'm making my own which will be no where near that price. Especially since i work in a steel shop and my buddies' work has a full on machine shop. Also if i was buying a new diff it wouldn't be GM's.
  15. #15 Re: rear coilover pics?
    Sep 2011
    Logansport, IN
    I agrre about making your own....with a little elbow grease, you can make your own for not much more than the cost of a good set of struts and lowering springs...that's what i am doing
  16. #16 Re: rear coilover pics?
    What struts are you using?
    Because quality struts cost big bucks.
  17. #17 Re: rear coilover pics?
    I got all dat stuff.
    I have about $3k in suspension alone and I'm still not done
  18. #18 Re: rear coilover pics?
    Quote Originally Posted by DrunkieTheBear View Post
    I'm still not done
    Believe me, I know...
  19. #19 Re: rear coilover pics?
    Sep 2011
    Logansport, IN
    I have a set of koni's that are getting custom two stage valving done by a race shop(a guy who does struts for the SCCA racers). I dont suppose you would want to sell a couple of rear upper mounts would ya?
  20. #20 Re: rear coilover pics?
    Aug 2008
    hamilton,oh
    quality struts are what i can afford. The 1500 dollar ones from hmt or whatever their name is are just made with kyb's anyways. Unless you wanna give closer to 2k for the koni's.
  1. Rear 02 ?
    By GreyGhost in forum General Tech Discussion
    Last Post: 02-15-2011, 12:26 PM
  2. new pics!! new rim/tires/rear led lights.
    By tmackster in forum Visual/Body Modifications
    Last Post: 10-18-2009, 12:25 AM
  3. rear o2
    Last Post: 04-21-2009, 02:54 PM
  4. You asked for them... pics pics and more pics!
    By miller in forum Off Topic Discussion
    Last Post: 07-30-2008, 05:33 AM
